CPUGauge V1.0 released!
    Posts: 918 from 2004/1/24
    Sick of MorphOS being so much faster than the rest? No? Well, CPUGauge will help you enjoy it to the max!
    Besides this, CPUGauge is a screenbar plugin for MorphOS and displays the current CPU load as a smooth sliding gauge in the screen title.
    Requirements: MorphOS 2.x (a system that can unpack a small lha in less than four minutes.)
    Download CPUGauge V1.0 HERE
  • »14.08.09 - 22:25
    Posts: 236 from 2003/7/28
    Nice little sbar.
    Thanks!
  • »15.08.09 - 00:36
    Jambalah
    Posts: 820 from 2008/3/30
    Oh, really nice!
    And full set of coloured bar! Thanks!!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »15.08.09 - 04:56
  • rms
    rms
    Posts: 606 from 2004/11/27
    Yes indeed, very nice :-) Great, thanx very much.
    So why not also releasing the MemoryGauge.sbar? Would be really great!
  • »15.08.09 - 07:14
    Posts: 649 from 2004/4/15
    It's looking really nice.
    But there seems to bo a bug in Mos with screenbars.
    Often the bars cover each other and the ordering cannot be changed.
  • »15.08.09 - 09:22
    Get27
    Posts: 90 from 2004/8/23
    Eliot :
    try without Memory sbar, i've got same problem when it's activated. (the problem seems to come from memory sbar)
    PowerMac 3.5, G4 1.0GHz DP, 1GB ram, 80GB HD + NAS, Radeon 9600 128MB Mac, 1680x1050
    PowerMac 7.3, G5 2.3GHz DP, 4GB ram, 160GB HD + NAS, Radeon 9800 128MB PC, 1680x1050
    Amiga 500+, Vampire 500v2+, HxC Floppy
  • »15.08.09 - 11:49
    @Get27
    Yes, your are right.
    Disabled Memory bar and everything is ok
  • »15.08.09 - 15:05
    @Eliot
    I haven't seen the bars cover each other, although I did have trouble re-ordering them.
  • »15.08.09 - 16:43
    dIGIMAN
    Posts: 273 from 2005/11/7
    eliot wrote:
    @Get27
    Maybe AmigaZeux will release a MemoryGauge someday..... :)
  • »16.08.09 - 08:06
    Posts: 12543 from 2003/5/22
    > great!
    They did :-)
  • »18.08.09 - 15:58
    Brumiga
    Posts: 276 from 2004/4/3
    Good evening,
    Could we hope that amigazeux could/would then also release a network.sbar as gauge or other in the tread ?
    Brumiga
    [ Edited by Brumiga on 2009/8/19 14:52 ]
  • »18.08.09 - 18:36
  • rms
    rms
    > great!
    They did :-)
    Yes indeed, really great thanks very much!
    About the NetworkGauge.sbar, if such would be possible, it would be very handy also.
    Regards
    Christoph
  • »20.08.09 - 05:51
