AutoDocReader 1.6 releaced
    MaaG
    Posts: 86 from 2003/7/22
    Hello,
    After long time I back to my little tool - AutoDocReader and fixed some bugs. Now more autodoc files are displayed properity. And add sort option in database editor menu. You can sort files into selected tree: after first button pressed from a.. z, after second pressed from z..a.
    Have a fun.
    Links:
    My webside and AutoDocReader v1.6 (version for AmigaOS3.x, AmigaOS4.x, MorphOS and AROS)
    [ Edited by MaaG on 2009/7/27 22:35 ]
  • »27.07.09 - 18:34
    ShInKurO
    Posts: 36 from 2008/5/30
    Thanks, I waited it from much time... but it doesn't show OS4.1 SDK autodoc properly yet, for example application.doc... :-(
    [ Edited by ShInKurO on 2009/7/28 9:10 ]
  • »28.07.09 - 05:08
    Papiosaur
    Posts: 2408 from 2003/4/10
    Thanks a lot MaaG for this new realease ;-)
    Question for MaaG: Can I install AutoDocReader on pack MorphOS Upgrade, please ?
    I would like to do a Developpers drawer with tools for them ;-)
    Papiosaur
  • »28.07.09 - 08:55
    MaaG
    @ShInKurO
    Fixed. ADR 1.6.1 works fine with your's sdk files. Just reload archive ;)
    @Papiosaur
    No problem. Just add all files from archive.
    If someone has any problem with ADR - please send bug report into bugtracker (see into ADR about window).
    If you create your's native language translation (or fixed/finished exits) - send it to me please ;).
  • »28.07.09 - 20:29
    ShInKurO
    10x :)
    Yet problems with:
    amigaguide_dtc.doc
    animation_dtc.doc
    dos.doc (A-Compatibility-Issue bad visualized)
    intuition.doc (boopsi bad visualized)
    port-handler.doc
    usbfd.doc (descriptor bad visualized)
    MCC_TextEditor.doc
  • »29.07.09 - 05:32
    MaaG
    amigaguide_dtc.doc --> looks good
    animation_dtc.doc --> looks good
    No. Problem is in autodoc file - all text from NAME, SYNOPSIS and SPECIAL VALUE are displayed always in higer window. In this function FUNCTION or DESCRIPTION section name can be used than SYNOPSIS
    intuition.doc (boopsi bad visualized) - used unkown section name (fixed)
    port-handler.doc - missing autodoc header (TABLE OF CONTENTS), then ADR displayed it as plain text
    usbfd.doc (descriptor bad visualized) - the same as intuition.doc
    MCC_TextEditor.doc - remove "(not yet implemented...)" string from functions table
    ADR 1.6.2 will be releaced soon... (testing)
    [ Edited by MaaG on 2009/7/29 23:53 ]
  • »29.07.09 - 18:55
    samo79
    Posts: 87 from 2003/7/26
    @MaaG
    I sent you an update for the italian translation but i'm not sure about e-mail, did you receive ? :-)
    BACK FOR THE FUTURE
    http://www.betatesting.it/backforthefuture
  • »30.07.09 - 08:23
    MaaG
    by samo79 on 2009/7/30 12:23:21
    Yes. Thanks a lot. I check it today and include to next releaced (maybe today too...)
  • »30.07.09 - 09:03
    ShInKurO
    Thanks!
    Why in the old versions of ADR I could creat folder groups for autodoc with drag&drop of items list over another item list and instead now on OS4 is not possible anymore?
  • »30.07.09 - 10:13
    samo79
    @MaaG
    BACK FOR THE FUTURE
  • »30.07.09 - 12:08
    MaaG
    ShInKurO:
    No. Older version of ADR not checking droped object. In new version you can drop file into group folder, but can't drop on other folder or drop group folder on file.
    But ADR uses NListTree class. Somethimes this class not working correctly or crashed. Thats all.
    [ Edited by MaaG on 2009/7/30 22:50 ]
  • »30.07.09 - 18:46
