MorphOS Developer
                Posts: 1520 from 2003/2/24
				Overlay is not supported at the moment. It would need patching cgx but it can be done if there is enough demand.
3D layers are supported and you can even leave out recorder window from the actual recording. But this is available only under MorphOS 2.3 or newer because with currently released MorphOS 2.2 it is not possible identify screens which are using 3D layers. Using layer filtering method on 2D layers would just result in corrupted graphics.
Here is
the release screenshot. As you see I am running MorphOS 2.2 because "Ignore recorder windows" (it does not ignore just main window but about and MUI prefs windows) is ghosted
Oh, and there is also OS2 compatible version. It of course supports MorphOS features when ran under MorphOS 2.
