April and transparency
    weiseb
    Posts: 215 from 2003/3/29
    Ok i am not really one of the early users.
    I am using pseudotransparency.
    My problem is that I have to click into the
    calendar to make it adopt to the background.
    Its grey before.
  • »14.06.09 - 08:25
    Posts: 423 from 2005/4/9
    yeah, thats how it is.
    we need a fixed april for morphos 2.x.
    until that happens this is the only way afaik.
    zx.spectrum@3.5
  • »14.06.09 - 09:16
    analogkid
    Posts: 720 from 2004/11/3
    I hope there will be a version April, which uses the real transparency features of MorphOS 2.x, not only the fake transparency.
  • »14.06.09 - 09:47
    Posts: 2217 from 2003/2/24
    But April still works on MorphOS 2.x when you use 2D layers.
  • »14.06.09 - 13:49
    xyphoid
    Posts: 870 from 2008/7/11
    I just d/l April v1.5 opened it, but I got a requestor pop up saying "Could not create Mui application"
    Posted with OWB1.3
  • »14.06.09 - 16:45
    weiseb
    Thanks for the answers
    @jPV
    Great tip. This worked indeed. Another workaround might be to cut out the matching part from my background picture and keep 3d layers activated.
    @analogkid
    Using real transparency would be the best solution but I dont dare to hope for a new version of april
    @xyphoid
    I did the same without (other) problems.
    If you post a snoopium log I will compare it with mine.
  • »14.06.09 - 18:34
    r-tea
    Posts: 317 from 2005/3/27
    Btw, why April 1.5 still says it's 1.291 from AD2006 ?
  • »14.06.09 - 18:56
    xyphoid
    @weiseb
    seems to be the entire mui pack
    [1] [ramlib] [Open] [MOSSYS:LIBS/mui/Colorfield.mui.elf] [Read] [Fail]
    [2] [ramlib] [Open] [MOSSYS:LIBS/mui/Colorfield.mui.elf] [Read] [Fail]
    [3] [ramlib] [Load] [MOSSYS:LIBS/mui/Colorfield.mui.elf] [] [Fail]
    [4] [ramlib] [Open] [MOSSYS:LIBS/mui/Colorfield.mui] [Read] [Fail]
    [5] [ramlib] [Open] [MOSSYS:LIBS/mui/Colorfield.mui] [Read] [Fail]
    [6] [ramlib] [Load] [MOSSYS:LIBS/mui/Colorfield.mui] [] [Fail]
    [7] [ramlib] [Open] [LIBS:mui/Colorfield.mui.elf] [Read] [Fail]
    [8] [ramlib] [Open] [LIBS:mui/Colorfield.mui.elf] [Read] [Fail]
    [9] [ramlib] [Load] [LIBS:mui/Colorfield.mui.elf] [] [Fail]
    [10] [ramlib] [Open] [mui/Colorfield.mui.elf] [Read] [Fail]
    [11] [ramlib] [Open] [mui/Colorfield.mui.elf] [Read] [Fail]
    [12] [ramlib] [Load] [mui/Colorfield.mui.elf] [] [Fail]
    [13] [ramlib] [Open] [muidebug] [Read] [Fail]
  • »14.06.09 - 20:56
    weiseb
    colorfield.mui should come with Morphos
    and resides in Sys:MorphOS/Classes/MUI/
    for me. Are you only showing fails?
    Maybe it is opened successfully later.
  • »15.06.09 - 17:00
    CountRaven
    Posts: 566 from 2007/12/10
    What is that April? Have not heard of it before (sorry).... Is it a kind of calendar or something?
  • »15.06.09 - 19:42
    xyphoid
    all fails all the way through(this was a partial post from snoop copying and pasting locked up owb due to mem i guess). this is typical of my setup, as i always get issues no one else seem to have on my efika. I had no luck with wet or wetter if i recall
    @count raven yes try it d/l from luckysoft.
    posted from macmini with firefox
  • »15.06.09 - 20:56
    Posts: 12543 from 2003/5/22
    > What is that April?
    https://morph.zone/modules/news/article.php?storyid=1071
  • »15.06.09 - 21:38
    Golem
    Posts: 766 from 2003/2/28
    @xyphoid
    A partial snoopium/snoopdos log like this is fairly useless, most fails you see are completely harmless and can usually be ignored. Go see if you don't have a Colorfield.mui in MOSSYS:Classes/MUI, if it is there it should be found.
  • »16.06.09 - 08:59
    xyphoid
    Btw thanks for the assistance, a few of the files were missing, got them all now.
    was there a fix? it has todays date as [b]SUN.[b] June 22 (it's actually monday )
    posted with owb 1.3
    [ Edited by xyphoid on 2009/6/22 0:04 ]
  • »22.06.09 - 01:57
