Attachments in e-mails from mac not readable - BinHex 4.0
  • rms
    rms
    Posts: 606 from 2004/11/27
    I have the problem that I'm not able to read attachments from one of
    my customers which sends them from a mac.
    The attachement can be any file, e. g. a jpg or a doc etc, when I try to
    double click on the icon on Ambient (it's a txt icon BTW) after saving it
    from the e-mail to the hd the text reader opens and the first line is:
    (This file must be converted with BinHex 4.0)
    Has anyone any experience with this, can anyone help me here? Is it
    possible to setup something in Ambient to decompress the archive (if it is
    one of course)?
    Thanks for your help.
    Regards
    Christoph
  • »04.05.09 - 08:16
    Golem
    Posts: 766 from 2003/2/28
    There are some utils on Aminet that should be able to convert those for you.
  • »04.05.09 - 09:12
  • rms
    rms
    Thanks for this info, it did it!
    Now could support for BinHex 4.0 be included directly in MorphOS?
    It seems that mac users use that a lot.
  • »06.05.09 - 02:52
    Neko
    Posts: 301 from 2003/2/24
    Most email clients worth a damn should decode it automatically....
    .. to be honest I've not seen BinHex used on a Mac since the dark ages (before OS X). The world moved to 8-bit MIME a hell of a long time ago.
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »06.05.09 - 13:23
