Newer DOSBox port
    Solo_Kazuki
    Posts: 194 from 2006/7/23
    In first words sorry for flooding this portal with posts, but I have long pause in activity on it. And it was big cumulation of questions and requests ;)
    So... is there possiblity that someone do the port of newer DOSBox version?
  • »11.02.08 - 21:11
    zukow
    Posts: 662 from 2005/2/9
    i have compiled 0.72 but it crashes badly at start
  • »12.02.08 - 08:33
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    I gave it a try since 0.70, and i can make it start and run (there are a few things regarding sound to fix, so that it starts), but the problem is that i get random (but quite frequent) crashes later in the program.
  • »12.02.08 - 12:05
    Solo_Kazuki
    It's sad to read this... is this only port problem, or overall version bug?
  • »13.02.08 - 09:33
    analogkid
    Posts: 722 from 2004/11/3
    I hope it's possible to fix the problem... Dosbox is really great!
  • »15.02.08 - 06:14
    Derringer
    Posts: 103 from 2008/8/4
    I tried the version of 0.63, but after i run some apps it crashes.
    For example i can 1000 to run the dir command, but when i run the setup of win3.1 or any game it crashed.
    What will be the problem?
    MorphOS PowerBook G4 1,67GHz, 2GB Ram, 250GBHdd, ATI 9700/128MB
    Morphos G5 2,7GHz, 8GB Ram, 500GB Hdd, ATi Passive cooled 9800 PRO/128MB
  • »21.09.08 - 20:05
