MorphOS 2 not working on EFIKA :-(
    serge
    Posts: 725 from 2003/2/20
    I'm afraid,
    The Efika install img doesn't work :-x
    boot scsi:0 morphos-2.0-efikainstall.img
    error : bootimage format is of an unknown format.
    I downloaded 3 times the install.img from 3 mirrors.
    I tryed 3 USB keys and have the same error message.
  • »01.07.08 - 08:04
    Leon
    Posts: 93 from 2003/11/28
    Join the club.
    I have tried to boot from my "world's most popular USB stick" Kingston DataTraveller 1GB and although it was recognized and shows up in show-scsi & devalias, I got the same errors you got.
    No matter if it is FAT or FAT32 and the MD5 file checksum is correct, I couldn't boot from the USB stick, so I went with the TFTP option and it worked.
    "Boot from a USB stick"... I wish the reality would be as easy as written in the readme file.
    Meanwhile, I could not see a place in the installer where I can enter my proxy server information, did I miss it?
    Proud owner of:
    Efika
    ABIT ATI 9200SE AGP 128MB
    40GB Samsung Hard Drive 5400rpm
    PowerMac 3.1 G4 350Mhz "Sawtooth" AGP
  • »01.07.08 - 08:11
    MrZammler
    Posts: 18 from 2003/3/3
    Well, it worked here for me (I even downloaded the morphos2.0.iso to the same stick and installed from there).
    Make sure your stick contains a partition. Dont know how to explain this, but e.g. in linux a stick can appear as either /dev/sdx or /dev/sdx1. Both are valid, but scsi:0 looks for the later.
    Does ls scsi:0 list the files in the stick?
  • »01.07.08 - 08:36
    serge
    I finaly had succes booting from the image on miror 1 with an usb key wich failed before.
    I started Iwiard and now MOS.iso is beeing downloading.
    COOL
    [ Edited by serge on 2008/7/1 12:25 ]
  • »01.07.08 - 08:36
    SoundSquare
    Posts: 1214 from 2004/12/1
    it works here, i'm loading it from a TFTP server through the LAN.
    But after 10 mins it's still booting.... it gets stuck at "Quark/Openfirmware"
  • »01.07.08 - 08:37
    NicePics13
    Posts: 63 from 2007/3/9
    Don't follow the instructions in the readme too rigidly.
    I booted the install image from a Kingston 512MB USB stick with boot hd0:0 morphos-2.0-efikainstall.img but it was too damn slow so I got a network timeout.
    Still, I had plenty of Linux partitions so the install image can be booted from one of those and you can keep the ISO itself on the USB stick (or download it as you install).
    MorphOS 2.0 is running nicely :-D
    CBM Amiga 1200 + 4MB AMITEK with 33MHz 68882 FPU
    PowerBook5,4 1024MB 1333MHz G4
  • »01.07.08 - 08:50
    amiades
    Posts: 231 from 2005/6/2
    I had some trouble with a 1gb Trekstor memstick. One like this:
    http://www.trekstor.de/dyn_files/products/usb-stick_me/detail/black.jpg
    Had random freezes, and everything was sloooooow...
    Then I tried a usb harddisk (trekstor too), and it worked much better. img load was faster, and the system felt lighter at all. Anyway, I finally had some extrange issues at the end of the installation. When IWizard copies all the files, when I reached something like 120 megs, and around 4000 files, MOS kept reading from the HD, but the efika HD didn't make any sound... I waited for a while, but it didn't finish. Finally, it freezed again xD. Tody I will try again...
  • »01.07.08 - 08:53
    NicePics13
    About the possible partition layout on a USB stick:
    Windows 98? usually formats the entire stick as a loop device so when you want to see what's on it from OF just type:
    ls hd0 <- list entire stick
    Linux can format the stick with a regular msdos partition table:
    ls hd0:0 <- list first partition on stick
  • »01.07.08 - 08:56
    serge
    After downloading the MOS.iso, the installation doesn't continu.
    I click on install button, but nothing happens.
  • »01.07.08 - 09:27
    SoundSquare
    select the directory where the iso was downloaded (don't select ram: as destination for the iso !)
    then select the partition you want to install it.
    then click on install.
    It's installing here, but MOS crashed twice already on my efika
    + that's very stupid to have the timeout warning DURING the install !!!
  • »01.07.08 - 09:39
    SoundSquare
    alright MOS 2.0 is finally installed on my efika
    now ... how can i boot it ???? where is the boot image ?
    nothing in the readme about it, unless i missed it.
    (two more crashes in the meanwhile during install)
    edit : ok i just noticed boot.img will try to boot it.
    edit2 : mm it boots but gets stuck on the butterfly logo. (trying the bootdevice argument)
    [ Edited by SoundSquare on 2008/7/1 12:53 ]
    [ Edited by SoundSquare on 2008/7/1 13:00 ]
    [ Edited by SoundSquare on 2008/7/1 13:01 ]
  • »01.07.08 - 09:47
    mvdhoning
    Posts: 5 from 2008/7/1
    you seem to get further then me.
    i just get to the part stating Morphos 2.0 Loading...
  • »01.07.08 - 10:02
    SoundSquare
    i installed MOS on the first partition (SFS) of my HD on the Efika.
    to boot it i used :
    boot hd:0 boot.img
    it boots until the butterfly logo saying "morphOS 2.0 loading" but nothing happens
    i tried
    boot hd:0 boot.img bootdevice=sda1 (or sdh1)
    same issue.
    does someone know how to boot MOS ????
    [ Edited by SoundSquare on 2008/7/1 13:08 ]
  • »01.07.08 - 10:07
    MrZammler
    Sorry, can't help.
    boot hd:0 boot.img boots MOS2 ok here.
    (Did notice a few freezes though, I think they only occured when I had a usb stick inserted).
  • »01.07.08 - 10:21
    mvdhoning
    hmm, i gues i try again this evening
    as a side note: what keyboard do you have. Mine is not responding. when the loading message is on
  • »01.07.08 - 10:24
    Posts: 2095 from 2003/6/4
    Have you checked that the sys partition is marked bootable? I had the prob, that during formating I thought I did that checkamark, but it wasn't taken into account (or I was confused..). I rebooted from stick and set the correct checkmark. Everything's fine since then.
  • »01.07.08 - 10:37
    shakenfr
    Posts: 10 from 2007/12/29
    I reboot to put the partition sys as bootable but after I have the same problem.
    "Morphos 2.0 loading" is the only message I can see
    Any other ideas ?
  • »01.07.08 - 10:47
    SoundSquare
    @Zylesea
    thanks ! you were right about the boot mark, it works now.
  • »01.07.08 - 11:02
    shakenfr
    Mistake of me. With a bootable partition It now works !!!
  • »01.07.08 - 11:10
    MrZammler
    Good to see you guys sorting that out.
    Here, though, I'm still getting random freezes...
  • »01.07.08 - 11:16
    SoundSquare
    The system freezes when enabling the 3D layers and moving a window. Everytime.
  • »01.07.08 - 12:00
    mvdhoning
    with the partition marked as bootable it now works :-)
    No freezes here but is this 3d thing something you have to turn on?
  • »01.07.08 - 13:12
    SoundSquare
    yes, but i just heard it's not included in the ISO.
    i guess that's why it crashes when turning it on on Efika.
  • »01.07.08 - 13:18
    BatteMan
    Posts: 294 from 2003/2/24
    3D is included... Don't you see shadow under windows ? Cube3D and Plender (for transparency) are not included 'cause they're third parties applications.
  • »01.07.08 - 17:07
    Senex
    Posts: 500 from 2003/2/17
    SCube has been made available meanwhile - looks indeed impressive! :-)
    http://kiero.binaryriot.org/scube.lha - everyone who downloads it please take note of the readme file
  • »01.07.08 - 20:07
