VLC 0.9.6f beta1 released!
    magnetic
    Posts: 2129 from 2003/3/1
    @naTmeg
    Namaste  8-)
    magnetic
  • »18.05.08 - 12:26
    Crumb
    Posts: 738 from 2003/2/24
    great!!!
    now gimme direct vmem graphics mode for my CV64 and I'll be happy :-D
  • »19.05.08 - 13:35
    naTmeg
    Posts: 135 from 2004/2/8
    beta4 is now avail:
    http://members.aon.at/natmeg/ports/vlc-0.8.6f-morphos_beta4.lha
    http://natmeg.stamey.at/ports/vlc-0.8.6f-morphos_beta4.lha
    2008.05.22 - beta4
    - Implemented DVD support with menus and mouse-control through libdvdnav.
    - Reworte condition-handling in naThreads. Now signals are used instead of simple delays.
    - Fixed a52/ac3 volume problem.
    - Fixed aspect-ratio problem.
    - Fixed wrong redraw at window-resize, both in wpa and overlay.
    - Some small fixes and improvements.
  • »22.05.08 - 08:03
    tokai
    Posts: 1289 from 2003/2/25
    Is the VLC: assign really required? Can't you just use PROGDIR:, natmeg?
    Assigns for the solely purpose that a single application can find its components/ files should really be a thing of the past these days.
  • »22.05.08 - 09:04
    naTmeg
    Well, it's built with --prefix=/vlc, instead of /usr/local.
    I must look where or what files depend...
  • »22.05.08 - 09:15
    tokai
    if VLC is a libnix compile then a /vlc path inside the binary would fail anyway. So I guess this prefix is just used for istallation (make install) target after all.
  • »22.05.08 - 09:45
    naTmeg
    Sorry guys :)
    2008.05.23 - beta4 hotfix
    - Fixed dependency bug that makes DVD access not working and crashing the app.
    - Now the device name is used, instad of device:unit. Like "ide.device:1" -> "CD0:".
    - Got rid of the VLC: assign. (thx tokai)
    (same filename)
  • »22.05.08 - 10:44
    Motosampy
    Posts: 199 from 2004/8/14
    Can't get correct aspect ratio, vlc uses always 4:3 though have tried --aspect-ratio xxx with all possible options that I can think of... anyone else having this problem ?
  • »22.05.08 - 15:06
    magnetic
    hmm 4:3 sux for movies...
    Natmeg: is anyone working on the gui?
  • »22.05.08 - 17:54
    AmigaMancer
    Posts: 265 from 2005/8/25
    I have tried to view some videos with VLC but it just quits silently. I ran snoopdos to see if there is a missing file and saw that VLC uses tinygl.library. Does this mean that it doesn't work with C/BVision, since there are no 3D drivers for these cards?
    Edit: Even "vlc --help" quits silently. :/
    [ Edited by AmigaMancer on 2008/5/24 10:16 ]
    Amiga 1200 user.
  • »24.05.08 - 05:34
    MorphDelf
    Posts: 274 from 2004/2/20
    I find VLC for MorphOS pretty stable. Its quite stable as beta release for MorphOS. Would be nice with GUI though, but its not an requirement if VLC already have pretty good DVD support itself.
  • »24.05.08 - 09:33
    koan
    Posts: 303 from 2005/11/21
    Nice port, works well here. With a GUI it will be
    perfect!
    Please add >= PowerSDL v12 to the list of requirements.
    (Get it from Aminet, for those who don't know).
  • »25.05.08 - 10:11
    naTmeg
    Next beta... :)
    http://members.aon.at/natmeg/ports/vlc-0.8.6f-morphos_beta5.lha
    http://members.aon.at/natmeg/ports/vlc-0.8.6f-morphos_beta5.readme
    2008.05.25 - beta5
    - Now keys from vlcrc are used and can be defined in there.
    - Implemented audio-volume handling to ahi_dev module.
    - Implemented wb-start and added VLC.info. (no tooltypes)
    - Fixed libdvdnav stuff. (now realy)
    - Fixed mouse-pointer offsets.
    - Fixed new-line problem in the shell.
    - Fixed config-load/save stuff.
    - Fixed option --longhelp crash.
    - Fixed all getenv(HOME) to PROGDIR:home.
    - Fixed hit when pressed the RMB.
    - Got rid of usergroup.library.
  • »25.05.08 - 15:51
    magnetic
    natmeg
    Very cool, thanks for your work on this. However, everyone keeps asking about a GUI and there is no answer. IS ANYONE working on this?
  • »25.05.08 - 18:22
    Crumb
    @magnetic
    create your own Magnetic GUI!:
    MUI Tutorial
    If you have doubts you can learn C programming
  • »26.05.08 - 07:09
    AmigaMancer
    Edit: Nevermind
    [ Edited by AmigaMancer on 2008/5/26 16:04 ]
    Amiga 1200 user.
  • »26.05.08 - 12:01
    naTmeg
    Another update... :)
    http://members.aon.at/natmeg/ports/vlc-0.8.6f-morphos_beta6.lha
    http://members.aon.at/natmeg/ports/vlc-0.8.6f-morphos_beta6.readme
    2008.06.01 - beta6
    - Added MorphOS OpenGL (TinyGL) provider module.
    - Added freetype-module, and so ttf-OSD text.
    - Added modplug-module for all kind of tracker-mods. (untested)
    - Improved all MorphOS modules. Combined functions, made things using less space and memory.
    - Enabled aspect-ratio- and corp-cycling when pressing 'a' or 'c'.
    - Prepared source for a mui interface module.
  • »31.05.08 - 14:47
