MorphOS 1.4.5/Pegasos problems
    Charvel
    Posts: 97 from 2007/2/15
    My Pegasos doesnt boot anymore.
    It just comes up with Quark/Openfirmware and it chews some time on the harddrive.
    Then nothing happens.
    I have not registred my pegasos 1 system yet because I didnt know it was the macadress that was the serialnumber.
    So I do not have a MorphOS cd )= .
    Anyone got a clue or idea how to solve this?
  • »04.04.08 - 16:04
    Golem
    Posts: 766 from 2003/2/28
    Did you change anything?
  • »04.04.08 - 16:19
    Charvel
    No.
    I just installed earth 2140 and when I started it, it froze.
    The harddrive is spinning up and it seems that it stops booting just before the MorphOS logo shows up.
  • »04.04.08 - 16:43
    Golem
    Ok, so the OF screen clears? Try adding a line with "Wait 1" before IPrefs in your startup-sequence.
    Oh.. no MorphOS CD? Mhh.. if you boot with ramdebug, try without, see if it boots then.
    [ Edited by Golem on 2008/4/4 16:58 ]
  • »04.04.08 - 16:55
    Charvel
    hrm... i have no MorphOSBootcd. And cant download it because I dont have registred.
    The openfirmware screen does not clear.
    it just stays with:
    Quark/Openfirmware
  • »04.04.08 - 18:43
