Posts: 451 from 2006/11/16
I tinkered with the settings in makecd.
I set the reading drive to the cdrom driver..was cdr atapi.
No it seems to work but no cdrom has been burned.
At least no icon showing up in ambient for this cdrom and my windows thing also doesn't see anything on the cdr.
Fpan does see a datatrack on the cdr.
I tried closing the disc in Fpan and makecd no help.
Do I need to fall back to a supported scsi cdromburner?
Like the yamaha CRW 4416? If I can find one I do have a scsi pci card inside which workes ok with my scanner.
But these old burners are not easy to find anymore.
Or can anybody confirm a working cdrom burner which does copy cd's?
I prefer ide as my case can only hold one cdromdrive and scsi is I think nogood for booting morhposcdrom if needed?
