MOS cd boot problem
    Amigaz
    Posts: 121 from 2005/6/11
    Got my first Peg (Peg 2) some days ago so now I'm a Pegasos user  :-) but have used MOS since some time on my Amiga 4000
    Today I finally got all the pieces to put it together, a brand new Ati Radeon 9250 and two 80pin rounded IDE cables
    but as usual I don't have any luck as I often don't have when I have a new system, I'm trying to boot the MOS 1.4.5 cd I got with the system and following the guide here http://www.morphos-news.de/beta2help/qstart_se.html
    But all I get is this  :-?
     Attached file(s)
    MorphOS PowerUP powered Amiga 4000
    Pegasos II G4 1ghz
    Radeon 8500 128mb
    Soundblaster Live 5.1 Digital
    Realtek 2139B 100mbit
  • »04.08.07 - 11:15
    Amigaz
    Forgot to add that I have a 40 gig Samsung hd connected as Master to the primary IDE port and a cd-rom to the secondary IDE port as Master
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »04.08.07 - 11:17
    tokai
    Posts: 1289 from 2003/2/25
    the filesystem error is probably normal in your case (as the hd is not installed yet and the firmware wants to boot from some partition (which probably doesn't exists yet))
    About the other error after your user input:
    the command is "ls" (L-S) and *not* "1s" (One-S).
    Hope that will help you to get a step further. Following the guide is an good idea already and usually you should be able to get the thing running in no time. :)
    [ Edited by tokai on 2007/8/4 14:57 ]
  • »04.08.07 - 11:53
    Golem
    Posts: 766 from 2003/2/28
    @tokai
    So are you psychic or does that smiley have some meaning that I'm not aware of?
  • »04.08.07 - 12:03
    Amigaz
    Ahhh...thanks
    But now I got this instead
    have tried 2 different cd-rom's
     Attached file(s)
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »04.08.07 - 12:45
    Amigaz
    doh, I tried "cdrom" instead of "cd" now which seemed to work :D
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »04.08.07 - 12:47
    weiseb
    Posts: 212 from 2003/3/29
    > @tokai
    Stealthmoderator
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=5134&forum=9#49485
  • »04.08.07 - 13:46
    keropi
    Posts: 131 from 2006/11/11
    my pegII's boot with this:
    boot cd boot.img
    ya like MOS amigo? it rocks!  :-)  :-)  :-) be sure to install latest MUI and ambient!
    A4000D CS-PPC/G-Rex4000D
    A4000D CS-PPC/Zorro
  • »04.08.07 - 13:59
    Amigaz
    boot cd boot.img
    hehe, haven't got that far yet....
    Now at least I can boot MOS from the hd which is only recolgnized as 8bb (looks like the old WB hd recognition)
    Next step is a big portion of MOS upgrading and getting MOSNET to work with the bulit in ethernet
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »04.08.07 - 14:19
    Golem
    Stealthmoderator
    Yeah I figured it might be that :)
  • »04.08.07 - 15:26
    tokai
    oh well.. approved the images. the system doesn't let you know at all if something like this needs approving or not. Maybe Targhan finds some option to disable this 'feature' ;)
  • »04.08.07 - 16:00
    keropi
    I see cat foot-prints on the monitor! LOL
    A4000D CS-PPC/Zorro
  • »05.08.07 - 07:15
    Amigaz
    Can you see what kind of animal which caused it?  ;-)
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »05.08.07 - 08:25
