Posts: 454 from 2006/11/16
I want to pack a partition with about 8.5 GB on data onto a 6 GB usb harddisk.
So it must be packed.
I am using peperoni from the aminet and tried the lzx and the zip pack method.
Both fail the .lzx just stops on 3% and the zip makes a non zip file at least it won't unpack either with voodoo or peperoni.
Has this something to do with the size off the partition.
Or do i need other lzx/lha/zip program.
Or is peperoni buggy?Like it's gui..
