Posts: 452 from 2006/11/16
Managed to get it formatted with SFS on my amiga4000 with scsiconfig.
Don't know why it won't work on the peg??
Maybe because poseidon is a higher version on 68k?
Anyways wanted to get the stick going with usbboot to have clean morphos install for testing/debugging.
But doesn't want to go what am I doing wrong?
1 copy usbboot to c:
2 format the stick with SFS...ok
3 edit morphos:s/startup-sequence execute s:usbboot
4 copy contents morphos cd to usbstick
Now it boots and then stops.
[ Edited by amiga4001 on 2007/5/19 7:46 ]
