MorphOS and 1680 x 1050 Dell Widescreen monitor?
    Schlonz
    Posts: 131 from 2004/4/16
    MorphDelf:
    Thanks!
    >Very cool to play fuhquake in 1280x1024 also.. playable :)
    So, the picture is stretched to fit the whole screen, or do you play it in window mode, or do you have black borders left and right?
    >or how about snes9x in a window on ambient desktop.
    Yeah, but this does work on a "normal" screen as well :-)
  • »24.02.07 - 20:56
    jcmarcos
    Posts: 1178 from 2003/3/13
    MorphDelf wrote:
    Here is my modeeditsetup
    Thankyou very much, Michal. I see that you specify a 85 Khz monitor. Would my old 15 inch CRT be able to reach such a frequency?
  • »26.02.07 - 12:15
    GMKai
    Posts: 256 from 2003/4/7
    to extend the thread:
    I have created a screenmode with 1600x1200.
    the mode ist testable and looks good in modeedit.
    why isn't it possible to select that mode for ambient?
  • »23.03.07 - 12:09
    Golem
    Posts: 766 from 2003/2/28
    Does any other app allow you to use it? Is it a high-/truecolour mode?
  • »23.03.07 - 12:18
    GMKai
    other apps weren't able to see it either.
    what did the trick was to change "scan mode" to "normal"
  • »23.03.07 - 12:36
