Mplayer DVD Playback.
    matt3
    Posts: 784 from 2004/2/10
    I'm having trouble play dvd's.
    I recently update all my player files (Mplayer, devedie, tdplayer)
    Now I can't get a dvd to play. Both Devedie and TDplayer do nothing when trying to play a dvd.
    Snoopdos shows trying to load a config file. There is a config file in the mplayer folder.
    Any ideas?
    Thanks,
    Matt
  • »12.02.07 - 01:48
  • mk
    mk
    Posts: 72 from 2004/5/24
    > matt3
    > Any ideas?
    DVD args have changed at version 1.x.
    -dvd {title}
    to:
    dvd://{title}
    (Read for more the Readme_1.0-PRE4.)
    I'm use modified playDVD to play DVD.
    http://www.christianrosentreter.com/download/tools/playdvd-1.2.lha
    old call in playDVD (mplayer 0.x):
    mplayer -dvd {title} -dvd-device ide.device:$unit $sub $aud -framedrop
    new call in playDVD (mplayer 1.x):
    mplayer dvd://{title} -dvd-device ide.device:$unit $sub $aud -framedrop -autosync 30
    [ Edited by mk on 2007/2/12 7:38 ]
  • »12.02.07 - 04:32
    Jupp3
    Posts: 1193 from 2003/2/24
    ...which reminds me, maybe I should finally fix mDVD to work with new mplayer argument format :-)
  • »12.02.07 - 05:55
    diezi7
    Posts: 167 from 2005/7/25
    Ohh yesss jupp3, would be cool if you update....
    thanks
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »12.02.07 - 06:22
    Jupp3
    Being arexx code, almost anyone could do that, I guess :-)
    But I'll see my code when I get home from work...
  • »12.02.07 - 09:43
    armo
    Posts: 40 from 2003/8/1
    Did you set "mplayer executable is v1.0+" in settings->mplayer/others of TDmplayerGUI? This option is important for DVD playback.
    Rafael/ARMO
    tdolphin.org     tdolphin.itch.io     GitHub
  • »13.02.07 - 04:26
    Posts: 108 from 2005/4/3
    Hi all,
    MPlayer of the "mplayer1.0rc1.lha" archive, some animations are not
    entirely played, they are cutt off. So, i use the MPlayer from the
    "mplayer1.0pre8-test.lha" archive again.
    Grts, Amigaharry
    http://www.angelfire.com/amiga/ex
  • »13.02.07 - 04:29
    matt3
    Hi Armo:
    I'm not able to play dvd's with TDmplayerGUI, I do have the option set and dvd playback doesn't work.
    I ran snoopdos and it fails:
    /user/local/etc/mplayer/inpu
    dvd.ifo
    dvd.rar
    dvd.rar
    dvd.idx
    dvd.rar
    dvd.rar
    ENV:DVDCSS_METHOD
    ENV:DVDCSS_VERBOSE
    ENV:DVDCSS_CACHE
    ENV:DVDCSS_RAW_DEVICE
    A window pops up and closes before I can read it...
    I am able to now play dvd's with mplayer (thanks guys!)
    Matt
  • »14.02.07 - 00:19
    armo
    Hi matt3
    If you have DVD connected to Pegasos as other than First-Slave (unit 1) then add in additional options "-dvd-device ide.device:$unit", where $unit is your unit :-)
    Next version of TDmplayerGUI will have appropriate settings for DVD/VideoCD device:unit.
    Rafael/ARMO
  • »14.02.07 - 12:06
    merko
    Posts: 328 from 2003/5/19
    I got the problem with DVD playback recently that audio is jittery and
    extremely noisy (far too bad to watch a movie). If I give the -ao
    ahi_dvd command it plays fine though, I suppose it uses the low level
    ahi output as default.
  • »14.02.07 - 13:14
