Posts: 265 from 2005/8/25
It really depends what kind of crash you have. The whole system freezes sounds bad... but it's maybe not an MLD fault.
Yeah, it probable that the freezes might not be related with mldonkey. Afterall, MorphOS doesn't run very stable on my Amiga, but i'm sure that these freezes occurs much, much more frequently when mldonkey downloads. I have confirm this many times.
Hard to tell w/o any information in the debug log
I know.
I can't connect my Amiga with another computer currently. Perhaps i will do it later.
It is possibly that it is a bug/ lockup in the network driver or something. I have no idea about the current state of that stuff for the PowerUp version here nor what are you using exactly. So maybe not MLD related at all.
I have tried both the old and the latest versions of Ambient/MUI. As for network drivers, i have a dialup connection so i don't use any. I have tried both genesis and miami. None of them makes a difference.
Thanks for replying.
Amiga 1200 user.
