MorhOSExecMonitor problem
    JohnFante
    Posts: 163 from 2006/9/4
    I have just installed MorphOSExecMonitor from AmigaZeus. A nice little app.
    Does anybody else have the problem that it begins to halt the system very chortly every couple of systems after a while especially when you play games? It kind of chops up things.
    I am sure it is ExecMonitor (or something related) that gives the problem since it dissapeard when I turned it off.
    Btw. does anybody have suggestions for other clocks / systemmonitors that the like /use?
    Thanks in advance.
  • »14.01.07 - 12:23
    Korni
    Posts: 473 from 2006/2/23
    I often turn MEM off, when i want to play some games. Check PowerSDL, MEM causes strange things with older versions. Now i deleted it from WBSTARTUP. I had issues with MEM after trance update. I had requester from AmIRC that it can't load vapor libs sometimes too. Try to
    1. Backup SYS:
    2. QuickFormat
    3. Put back SYS:
    4. Dunno why, after that i installed 3dupd, because 3D didnt work in Quake/Quake3
    It helped me a lot, MorphOS runs perfectly. I prefer statline, i'm using it instead of MEM.
    http://img403.imageshack.us/my.php?image=statlineig2.png
    [ Edited by Korni on 2007/1/14 16:49 ]
  • »14.01.07 - 13:39
