Mui4 Download
    amiga4001
    Posts: 454 from 2006/11/16
    Where can I download this mui4?
    Is it still Beta and/or is it stable?
    What improvements does it give to add to a standard 1.4.5 install?
  • »23.12.06 - 07:29
    AmigaMancer
    Posts: 265 from 2005/8/25
    http://www.stuntz.com/muibeta_20060922.lha
    It is both.
    You can read the included changelog if you like. Newer version of Ambient and Sputnik requires it.
    Amiga 1200 user.
  • »23.12.06 - 08:57
    amiga4001
    Tried to install it.
    Installer failed in the last bit I think.
    Had to reinstall everything.
    Must make a backup off the boot partition first now.
    What is a nice stable amibient and where to get it?
  • »24.12.06 - 07:39
    AmigaMancer
    http://fabportnawak.free.fr/ambient/ambient-1.43-20061111.lha
    Amiga 1200 user.
  • »24.12.06 - 08:40
    amiga4001
    Thanks for the link's.
    Installed MUI4 now and the new ambient.
    Very neat ....mimetypes! and very nice config screem this mui4.
    But again some prblems..
    Simplemail and some other less important things are not reacting very good on mui4 it is very slow on startup now.
    Due to some muiclasses?
  • »26.12.06 - 18:05
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Make sure you have ramdebug enabled. MUI4 displays more debug information, and broken classes like nlist make it scream. With serial debug it would make it quite slow.
  • »26.12.06 - 18:39
    amiga4001
    Where can I set this ramdebug option.
    And where if activated can I find the output?
    Any help is welcome love the community!
  • »26.12.06 - 19:30
  • Fab
    Fab
    In the command line you use to run morphos (startup arguments in s:startup-sequence), add ramdebug switch if it's not already there. But it's set as default IIRC on mos pup.
  • »26.12.06 - 19:59
    amiga4001
    No real errors showed with this ramdebug option.
    Seems Simplemail is not compatible with MUI4?
    Can anybody confirm this?
    Well it starts up allright but incoming is empty.
    When I switch to outgoing and then back it shows the list.
    Also it used to start up a lot faster.
    Is there a place where I can download mui4 compatible .mcc?
    Thinking it has something to do with this.
    Else I am going back to original mui version which reacts a lot faster but with a lot less gizmo's.
  • »26.12.06 - 20:47
    Posts: 1932 from 2003/10/19
    I use simplemail with no problems on the latest MUI4 and the latest Ambient build from the latest sources. I'm not sure what the problem could be for your system.
    If you decide to go back make sure you restore ambient to the correct version too. It will mess up your system if you dont.
    [ Edited by Acill on 2006/12/26 15:22 ]
  • »26.12.06 - 21:21
  • Fab
    Fab
    ramdebug is not meant to show errors, but to send them to ram instead of serial port, which is much faster. Anyway i'm not sure what your problem really is. Could you send a ramdebug dump after starting simplemail (use getramdebuglog tool)? Maybe we'll see what's wrong.
    And about that empty list at startup, it's just yet another nlist bug. MUI4 is not at fault, broken nlist class is responsible for all this mess.
  • »27.12.06 - 01:24
    AmigaMancer
    No. It's a known, small problem with MUI 4. It is not SimpleMail related. If you search in this forum, you will find some recent references to it.
    Probably because you have a very fast computer.
    Amiga 1200 user.
  • »27.12.06 - 11:54
    SoundSquare
    Posts: 1214 from 2004/12/1
    then i do too ! everything runs fine here as well.
  • »27.12.06 - 17:20
    amiga4001
    Strange I have a peg2 which is even overclocked to 1.27 GHz.
    So should be fast enough.
    Can anybody who's system is running stable send me his mui classes?
    With a pm for emailadres?
    Still thinking it is some mui class which is causing problems.
  • »27.12.06 - 18:07
    BatteMan
    Posts: 294 from 2003/2/24
    amiga4001 : You probably use the serial debug...
    Add "ramdebug" in your bootline on Firmware. You should have something like this :
    boot ide:0 boot.img ramdebug
    The serial debug slows down your MorphOS a lot !
    /me is always in ramdebug.
    [ Edited by BatteMan on 2006/12/27 16:28 ]
  • »27.12.06 - 21:27
    Posts: 423 from 2005/4/9
    an overclocked peg? :)
    can you tell me more about it please?:)
    if its offtopic, use the pm.
    is it possible to oc. my 600mhz g3 too?
    zx.spectrum@3.5
  • »27.12.06 - 22:54
    amiga4001
    I did buy it this way don't know how or what.
    Only that it runs at 1.27GHz and is absolutely stabil.
    Is it much faster then a normal one??
    I have yet not seen a peg2 to compare this with.
    Think so..
  • »28.12.06 - 04:34
    Senex
    Posts: 500 from 2003/2/17
    In case you understand German, you can find the required information at the Pegasosforum.
  • »28.12.06 - 05:06
