Extremely slow loadingtimes on Quake3
    JohnFante
    Posts: 158 from 2006/9/4
    I have just installed Bigfoots Quake3 port and the game works like a charm.
    The problem is that the loading times a ekstremly long. It takes forever to load a level. Forever mining minutes.
    I have a Peg2 1Ghz, 512 MB Ram and a Radeon 9250 so my specs a ok.
    On another note. Does the defrag program in MorphOS work? When i start it I just get a emty window with no drive details.
    I have a 80GB hd set to cable select. Standard hd supplied by vesalia.
    Thanks in advance.
  • »02.12.06 - 14:19
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    Do you use FFS? I remember someone having a similar issue. Game would take several minutes to start on FFS. Try SFS and see if it's better.
  • »02.12.06 - 14:58
    JohnFante
    I am using FFS.
    I will try SFS. Can I use the newest SFS?
    Thanks!
  • »02.12.06 - 15:08
    hooligan
    Posts: 1948 from 2003/2/23
    addbuffers 1000 will solve the problem
  • »02.12.06 - 15:38
    JohnFante
    Thanks for that. Can anybody help with the SFS question? Witch version can I use. I remeber reading that the newest is'nt good on MorphOS.
    [ Edited by JohnFante on 2006/12/2 16:43 ]
  • »02.12.06 - 15:42
    Wishmaster
    Posts: 342 from 2003/6/29
    User the one, which is included in the boot image.
    Pegasos PPC
  • »02.12.06 - 16:01
    JohnFante
    And how do I do that?
    And now that I am at it. How do I change a drive from FFS to SFS. I tried to do it as I did on my old A4000 but the only result was that my DH0 drive disappeard and I had to use the MorphOS boot cd to change it back.
    Sorry for all the noob questions.
  • »02.12.06 - 16:30
    hooligan
    Unfortunately you will lose all data when changing filesystem. Do a back up to another partition/drive/cd/dvd
  • »02.12.06 - 16:40
    JohnFante
    Ok. Thanks!
    I will "upgrade" to SFS then.
  • »02.12.06 - 17:36
    diezi7
    Posts: 167 from 2005/7/26
    True, I think it was me :) . The problem was solved
    turning an ffs partition into SFS as some of you pointed out. You?ll note a big
    difference in loading times.
    Regards
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »03.12.06 - 10:01
