Filetransfer problem between TwinVNC and TightVNC
    JohnFante
    Posts: 163 from 2006/9/4
    I have TightVNC 1.38 running on my XP box (I know it is bad) and the latest TwinVNC on MorphOS.
    I get a fine connection to my XP desktop on MorphOS but I can't to get it to transfer files. When I press the transfer file icon a very small box comes up where you can only press ok. Thats it.
    Any ideas?
    In the meentime I will downgrade to TightVNC 1.29 (latest stable) and see if that helps.
    Thanks in advance!
  • »28.11.06 - 19:36
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    File transfer is not supported yet in TwinVNC.
  • »28.11.06 - 20:44
    JohnFante
    OK. :-) That explains a lot.
    Any MorphOS VNC client that does?
  • »29.11.06 - 03:36
    GK_LKA
    Posts: 481 from 2004/3/28
    None. Use FTP or Samba for file transfer!
    [ GK / LKA Team ]
  • »29.11.06 - 05:54
    Posts: 108 from 2005/4/3
    Hi all,
    RDesktop 1.4.1-MorphOS (04/19/06) maybe ? I registered the Remote Desktop Protocol Client.
    As it needs NT4TS/2000/2003/XP, i can not use, because these Operating System
    i do not own. I use Samba for filetransfer with Windows98.
    Grts, Amigaharry
    http://www.angelfire.com/amiga/ex
  • »29.11.06 - 14:38
