mos 1.4 and printing
    klapdeur
    Posts: 132 from 2003/6/28
    hi guys i have a prob that i cannot print with turboprint. i have a espon printer connected to the parellel prot of peg but when is want to print it does nothing? got any help ??
    wich device must i choose enz.
  • »09.08.03 - 18:21
    AC-Eule
    Posts: 129 from 2003/4/19
    This is normal or couzld you print with MOS1.3 before ?
  • »09.08.03 - 21:20
    Senex
    Posts: 500 from 2003/2/17
    Hm, have an EpsonSC640 here on the parallel device and that works. Does SnoopDOS give you any hints?
  • »10.08.03 - 07:07
    klapdeur
    how are your settings then and had you turboprint allready on the system i didnt i waited for this release of mos
  • »10.08.03 - 11:02
    Posts: 20 from 2003/7/11
  • »10.08.03 - 14:41
    klapdeur
    i now can print only with amigawriter but nothing else will print stuf not fxpaint and grafiche plublicher doesnt work what im doing wrong ???
  • »10.08.03 - 17:57
    gunne
    Posts: 441 from 2003/2/25
    Hi Johan
    Well, network-printing... :-)
    I have not tried printing with the Pegasos myself yet, haven't have any need for this yet. But I see that it seems people having various results for some reasons, for some printing seems to work and some say is doesn't work.
    Think I have to do a try myself. Sofar I normally save files over the network from the Pegasos, when doing work on this.
    Amiganetfs is good to use between Amigas, and works also very good in MorphOS.
    I print throw network using samba, have the printer connected to an Amiga, and it works good.
    Maybe you simply can print to a file and when saved, copy the file to the printer, likely the way samba-printing works.
    I'm not familiar with Axis, how does it works ?
    About netpar.device it might be that this device is written for and use the Amiga parallelport, and therefore of course not will work with some other parallellport. Have never used this device as I remember.
    Cheers
    Gunne
    Best wishes, Gunne
  • »10.08.03 - 18:29
    gunne
    Hi klapdeur
    If printing works with one software and not with another, one could imagine that it is some misconfiguration in that software that doesn't work.
    Maybe you have to do some configuration in the software and specify which device to use etc things...
    Cheers
    Gunne
    Best wishes, Gunne
  • »10.08.03 - 18:34
    klapdeur
    i tried that but its nog to configure in tode programs only density they have to use the standaard printer of the system
  • »10.08.03 - 19:10
    Well...the Axisbox is simply just two networkconnected parallellports in a box to which you assign IP information and gatewaysettings if needed.
    From your workstation you simply have to point out which IP address and port your printer resides on.
    Ie. pr1@10.42.43.50
    Above example states that the datastream should be sent to the first parallellport (pr1) on the device 10.42.43.50.
    Yes...of course the netpar.device could be confused if the parallellport is not the same, but the intent of netpar.device is to capture the information before it reaches the parallellport and redirect it onto the network according to the configurationfile where you put the above IP information among other things.
    Axisboxes and similar ones often handles more than one protocol, such as NetBIOS, IPX/SPX and Appletalk which makes them suitable for almost any kind of networking environment.
  • »11.08.03 - 04:01
    gunne
    Tried some printing. Printed to a file on another machine, and it did work very fine printing with Pagestream and Finalwriter. However printing with CED and fxPaint wasn't succesfull.
    CED prints to prt: so maybe its needed to make some remapping here, no time to look on this right now.
    About netpar.device and Axis; Thanks for the information. I did take a look on it, and it seems to be two versions available on aminet, NetPar & NetParLpr. Maybe you have to try some different versions ?
    Cheers
    Gunne
    Best wishes, Gunne
  • »11.08.03 - 05:51
    DSLCC
    Posts: 246 from 2003/5/14
    I'm having trouble also. I think it is my ignorance on how to use
    turpboprint. :-(
    Is there a device that needs to be specified. I'm using an Epson
    StylusColor 500.
    Thanks!
    Pegasos 1 G3 MorphOS 1.4.5* Mac G4 Sawtooth 1Ghz Tiger 10.4.1* Both Rock! :-D
  • »11.08.03 - 18:38
    Posts: 126 from 2003/2/17
    I'm currently printing using TCP/IP using lpr.device (os3.9 contrib dir) on a HP Deskjet 930C and laserjet5L.. works fine, but I can't print from iospirit apps and If i send something to prt: mos crashes
  • »12.08.03 - 02:13
  • »12.08.03 - 02:19
  • »12.08.03 - 03:50
  • »12.08.03 - 03:54
    Did you use any configfile to go with it ?
    Yep, really easy, everything is explained clearly in the documentation so RTFM
    BTW source code is included :) :-)  :-)
  • »12.08.03 - 07:40
