MPlayer bug
    GK_LKA
    Posts: 481 from 2004/3/28
    Ave!
    Sometimes MPlayer just can't open overlay and falls back to vmem diplay (it's windows cannot be resized, and the playback is much slower). The promlem appears when some programs are broken or when the computer has very long uptime, but I'm really interested in, what it causes. Other programs don't use the overlay. The only solution I've found is to restart the computer. I have a Radeon9200SE (128MB RAM), MOS 1.4.5 and MPlayer 1.0pre4 (olver versions also did this). Does anybody know what's wrong?
    [ Edited by GK_LKA on 2006/7/16 17:44 ]
    [ GK / LKA Team ]
  • »16.07.06 - 16:43
    Bladerunner
    Posts: 418 from 2004/2/19
    This is not a Mplayer Bug, but a bug with the CGX Drivers introduced with Mos 1.4.5
    In fact no prog which uses overlay (snes for example) does work then.
    I was not able to reproduce that, it just "suddenly" happen, like you when
    having long uptimes, if I use AE for a while I can be pretty sure that overlay
    does not longer work and so on.
  • »16.07.06 - 16:51
    marcik
    Posts: 268 from 2003/4/12
    If overlay is used once it stays for ever (atleast that's happening on my peg) so i made a 0.1s movie with mencoder, simple wbstartup script and it lanuches mplayer with that movie on start-up. Since then i have no problems with overlay anymore.
  • »16.07.06 - 17:22
    Posts: 108 from 2005/4/3
    MPlayer for MorphOS 1.0pre7-2.95.3 is the actual version.
    Overlay, i use it with VICE, the Commodore64 emulator from http://www.amidog.com
    There, you can find also AMP2, which is a movie and DVD player also ported to MorphOS.
    For correct working of AMP2, you need a keyfile, purchase from amidog.
    Grts, Amigaharry, my Amiga/Pegasos page:
    http://www.angelfire.com/amiga/ex
  • »16.07.06 - 17:51
    beanbandit
    Posts: 50 from 2006/4/19
    the latest version of Mplayer is actually 1.0pre8.
    mplayer now actually supports playing of WMV3 movies
    with regard to the loss of overlay, there are a couple
    of things
    1) increase the stack of the monitor file (after I increased it
    substantialy this 'error/bug' has not occured for me again (knock on wood).
    2) IF you then get this fault
    run loadmondrvs, then you will recover your overlay
    abilities :-)
  • »16.07.06 - 18:03
    GK_LKA
    Hm... I wanted to write pre7, don't know why I wrote pre4 instead of it ;) But is pre8 already ported to MOS? Where can I find it?
    Thanks for your advice, I'll try them when the problem occours again.
    EDIT: It came in short time: The loadmondrvs command solved the problem. Thanks again!
    [ Edited by GK_LKA on 2006/7/16 23:58 ]
    [ GK / LKA Team ]
  • »16.07.06 - 21:09
    AmigaMancer
    Posts: 265 from 2005/8/25
    Woohoo! Somebody upload it somewhere! :-)
    Amiga 1200 user.
  • »17.07.06 - 01:31
    CISC
    Posts: 619 from 2005/8/27
    It's here for quite a while already (and BTW, WMV3 support is still somewhat buggy)...
    - CISC
  • »17.07.06 - 04:29
    AmigaMancer
    Nice! I tried some wmv3 videos and they play without problems. :-)
    I want to report something that i notice in this and in the previous version too. When i try to play a file in VMEM mode, it plays ok and much faster than wpa of course, but the whole video gets a bluish tint. Also when i choose to display the video in fullscreen while i use the VMEM mode (f key), the system freezes. Perhaps it's a problem with the permedia2 chip/driver or just a fault of my configuration.
    Amiga 1200 user.
  • »17.07.06 - 10:17
    GK_LKA
    @CISC
    Thanks a lot!
    I think we really need a central homepage where everyone can download tha latest mplayer versions, because I think the releases are very chaotic, every release is by different people and is in different places. And of course there is sadly no news when one new version comes out. :(
    [ GK / LKA Team ]
  • »17.07.06 - 10:23
    Hi all & @CISC !
    Donated $65 for ARexxPPC bounty on 16 june. Targhan, please update the MorphBounty page with
    this amount of money. Amidogs AMP2 MorphOS version, i'am able to watch a music DVD ! The AMP.key
    keyfile is in the AMP2 directory too. You can find the AMP2-MOS.lha archive on Aminet.
    Grts, Amigaharry
  • »17.07.06 - 20:24
