Digital Almanac III MorphOS native
    Posts: 1520 from 2003/2/24
    I just built MorphOS native Digital Almanac III binary. Since I dont have CD I cant test if it really works but please try it nevertheless :-)
    MorphOS native binary is available here (about 400K).
  • »05.03.05 - 16:17
    Senex
    Posts: 500 from 2003/2/17
    Thank you very much! But here it fails looking for easyftp.library - where can I get this?
  • »05.03.05 - 16:54
    Senex
    Here are my SnoopDOS.logs - one when being online (then it looks for easyftp.library), one when being offline. Please let me know if you need further information.
  • »05.03.05 - 17:25
    It should work without easyftp.library and shouldnt fail if it is missing. It can crash later though... If it is not present it proceeds and opens other libraries (xadmaster.library, openurl, jpeg.library (WOS version doesnt work)). Here it failed to load Data/mars.data (please enable more DOS operations from SnoopDos prefs). Shouldnt matter are you online or offline... but... I'm not very familiar with sources.
    Regarding easyftp.library it seems to be available nowhere. Couldnt find by google or from Aminet and had to construct library jump tables by hand... DA3 uses lot of rare abandonware.
  • »05.03.05 - 17:48
    Robin
    Posts: 741 from 2003/2/24
    I'm on isdn, so cant check this file ... but it's
    the only one with easyftp in the readme ...
    http://my.morphosi.net/?modul=aminet&full=on&find=easyftp
    http://my.morphosi.net/?modul=aminet&mode=readme&id=31515
  • »05.03.05 - 17:59
    Bodie_CI5
    Posts: 99 from 2004/6/19
    Bah! If I had the cash, I'd buy you an A1 to get proggies ported over onto OS4 as well... you seem to be one of the most productive developers out there. Cheers for the port though :pint:
    An ode to Wayne Miller:
    "Oooooh yeahh!"
  • »06.03.05 - 05:49
    discreetfx
    Posts: 400 from 2003/7/26
    Where can we buy the DA III CD?
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »06.03.05 - 11:36
    MarK
    Posts: 641 from 2004/1/25
    Is there a way to control some of current telescopes with DA3??? That would be cool!
    Bye, MarK.
  • »07.03.05 - 08:09
    @senex
    Hmm.. unfortunately that is not helping much... it seems it doesnt even start properly. I assume you have complete DA3 installation there and it works with original binary?
  • »07.03.05 - 18:13
    Senex
    Yes... Sorry I can't be of help.  :-(
  • »08.03.05 - 06:40
  • News Moderator
    News Moderator
    Darth_X
    Posts: 571 from 2003/2/10
     :-D Nah, just sell your A1 and buy yourself 2 Pegasos's!  ;-)
  • »09.04.05 - 23:55
    Posts: 33 from 2003/6/17
    Hello, the easyftp.library is on the DA3 CD. The ISO can be downloaded from the Aminet!
    [ Edited by grooves on 2006/3/10 9:15 ]
    PegII, 512 MB Ram, Radeon 8500, NEC USB-Card
  • »09.03.06 - 15:47
    Framiga
    Posts: 363 from 2003/7/11
    Hi itix
    "Here it failed to load Data/mars.data"
    here too with the original executables and yours as well.
    Have you found then why it fails at that mars.data?
    Here i can see(SnoopDOS) until the "Data/jupiter.data" and then nothing. (MOS and AmigaOS)
  • »10.03.06 - 13:32
