Posts: 2098 from 2003/6/4
@ lushka
Sure FF is open source, but that alone is not enough. It uses the GTK or MFC frameworrk very much. Both of that frameworks are not available for MOS. Well, there is the GTK->MUI wrapper, but it is still a lot of work...
The KHTML approch is way better suited for MOS. And I guess we can have some faith in Marcik, he showed quite promising results already. But it takes some time.
If you are eager to help you may consider to contact the AWeb team, coders are always welcome there I guess...
