CISC's gcc
    winterhunter
    Posts: 204 from 2005/10/13
    I had some trouble compiling some apps (SDK's gcc throws an internal
    error at me), and I was told to use CISC's gcc (Fab could compile the
    same app with it).
    Does someone know where to get CISC's gcc?? I've tried to google for
    it, but since "Complex Instruction Set Computer" is a quite common
    hit...
  • »07.01.06 - 09:11
    naTmeg
    Posts: 135 from 2004/2/8
    try http://developer.morphosppc.com/index.php
  • »07.01.06 - 09:25
    winterhunter
    I will try to compile it with the gcc present at the MDC, which is
    based upon CISC's gcc.
  • »07.01.06 - 18:49
    thefab
    Posts: 92 from 2003/8/19
    you don't seem to know but, hmm... CISC is a developper of the morphos team, and not a kind of artefact from another world :)
    and so, many sdk update on the mdc website are provided by him ;)
  • »07.01.06 - 21:42
    winterhunter
    I knew he wasn't some strange artifact (artifcacts don't post
    messages, right?), but I didn't know he was part of the MOS dev team.
  • »08.01.06 - 12:19
    CISC
    Posts: 619 from 2005/8/27
    Well, depending on your problem that might not work...
    F.ex. C++ (templates mainly) is known to be somewhat b0rken with the GCC in the SDK, unfortunately my GCC build (that used to be available on morphos.org) has been removed by Zapek, so to get it you must find someone that can send it to you (and if you do, replace the g++, cc1plus and libstdc.a binaries (and you MUST remember to disable/remove the GCCRESIDENT envvar!)).
    ..and don't forget to run the libnix update, it will fix several other issues with the SDK (stacksizes, missing includes, badly placed libs etc)!
    - CISC
    [ Edited by CISC on 2006/1/8 19:01 ]
  • »08.01.06 - 15:59
    gunne
    Posts: 441 from 2003/2/25
    CISC,
    Well, can this archive eventually be this ?
    Link
    Gunne
    Best wishes, Gunne
  • »10.01.06 - 11:41
    CISC
    That looks like it indeed.
    - CISC
  • »10.01.06 - 12:22
    gunne
    Hi again CISC,
    Ok, wonder why it always seems to happens in 'Amiga-land' that software disappears... ?
    No offence for you of course :-)
    Gunne
    Best wishes, Gunne
  • »10.01.06 - 19:55
    CISC
    Don't see how, not my fault Zapek goes ape-faeces. ;)
    - CISC
  • »10.01.06 - 20:38
    gunne
    Bring back the software :-)
    Gunne
    Best wishes, Gunne
  • »11.01.06 - 07:03
    Crumb
    Posts: 737 from 2003/2/24
    @CISC:
    erm...
    may I ask you why your fixed c++ stuff isn't included with the GCC compiler of the mdc?
    May you provide the sources to zero-hero so he adds C++ support to his Win crosscompiler?
  • »11.01.06 - 10:15
    CISC
    Because it isn't residentable, and at some point we'll have to release a much improved SDK altogether anyway...
    AFAIK zerohero's crosscompiler IS based on my sources (which also used to be available at morphos.org), why it doesn't support C++ I don't know.
    - CISC
  • »11.01.06 - 18:19
