Moderator
Posts: 500 from 2003/2/17
visit PpcZone
The only problem is that currently one can't post to their forum (server error already reported).
So please excuse me for asking here instead:
I've got a problem with online-updates on SUSE 10. Guess it's because I didn't download the 10.0 final ISOs but the 10.1 alpha - so my fault, but maybe it can be easily fixed with your help?
Symptoms:
1) While the addition of additional installations sources does work for 3rd party sites (like the PPC multimedia RPMs mentioned at PPCZone), I can't add one of the SuSE mirrors. No matter how I vary the pathes and mirrors, I always get the error "no_instsrc_on_media".
So what mirror/path do you enter to keep your installation up-to-date?
2) SuSE Watcher doesn't work here. Can't connect, although otherwise the internet connection does work (browser). Looking at the "details" output when trying an online update, it seems that it tries to connect to the URL "www.suse.de<br>".
Which configuration file do I have to edit to change this wrong entry?
(Could only find the YaST2 server files, i.e. the entries for the CD drive where I installed SuSE from and that hungarian server already mentioned.)
