NallePUH
    Toto
    Posts: 268 from 2003/4/20
    I found NallePUH on the AHI beta site in the tools directory. It's a
    hack that intercepts some custom chip register accesses and turns them
    into AHI function calls. Has anybody tried it? If it works it could
    mean that more Amiga software is usable on MoprhOS. I'm gone trie to
    get it working later this week.
  • »25.03.04 - 12:45
    Posts: 1087 from 2003/3/24
    No it don't work on MOS, it works with Amithlon. :-(
  • »25.03.04 - 12:50
    Posts: 2565 from 2003/2/24
    @ThePlayer
    Not correct !
    "NallePuh" only works on real Amigas with MMU (68030 and higher),
    while you would need it's brother "PuhDerBaer" for Amithlon.
    Both use the MMU to do the trick, and therefore can't be ported to
    the ABox.
  • »25.03.04 - 14:42
    Yes you are right Kronos had forgoten about that!
  • »25.03.04 - 17:16
  • News Moderator
    News Moderator
    Darth_X
    Posts: 571 from 2003/2/10
    is NallePUH something that could be re-written for MorphOS?
  • »30.09.05 - 00:06
    Golem
    Posts: 766 from 2003/2/28
    Nevermind....
    [ Edited by Golem on 2005/9/30 5:07 ]
  • »30.09.05 - 01:05
    Wishmaster
    Posts: 342 from 2003/6/29
    only by the MorphOS core devs, but I think they don't like such dirty hacks.
    Pegasos PPC
  • »30.09.05 - 03:41
    Posts: 261 from 2003/3/13
    Why would someone need such SW on MOS ?
    We have a audio.device clone, payback
    works for example more or less.
    Gr,
    Felix.
  • »30.09.05 - 04:23
    Wishmaster
    NallePuh is for prgs directly hitting on the metal without using audio.device.
    Pegasos PPC
  • »30.09.05 - 05:25
