Ambient docs?
    Navigator
    Posts: 11 from 2005/9/14
    Are there any guide file's or "how to's" available
    for Ambient anywhere? MorphOS and Ambient are new
    to me. I downloaded a new skin and the installer
    script for the skin wasn't finding directory's
    where it was looking for them. Some info on
    correct directory location and how to modify
    Ambient would be really helpfull. Thanks.
    Navigator
  • »19.09.05 - 09:45
    aliem
    Posts: 85 from 2003/12/11
    You could install your skin in the MOSSYS:Prefs/Skins Directory.
    after that you could change the skin of the Ambient screen using System Preferencies in ScreenMode section and edit Ambient screen.
    That's all :)
  • »19.09.05 - 10:23
    Golem
    Posts: 766 from 2003/2/28
    Don't put 3rd party skins in MOSSYS:, they belong in SYS:Prefs/Skins.
  • »19.09.05 - 12:55
    Navigator
    I read an Ambient review that mentions the directory
    arrangement is similar to AOS. Since it's not
    identical, is MOSSYS: created when Ambient is
    installed? Thanks!
    Navigator
  • »20.09.05 - 04:45
    Jupp3
    Posts: 1193 from 2003/2/24
    is MOSSYS: created when Ambient is installed?
    No, it's created when morphos is installed (but also Ambient is there)
    It's created so that some programs wouldn't overwrite (native) commands and libraries with old 68k version.
    If you take a closer look at mossys: (sys:morphos/) you'll see that it contains many same directories as sys:
    If there are 2 libraries with the same name, one in sys:libs and the other in mossys:libs, the one at mossys:libs gets used instead.
  • »20.09.05 - 06:42
    Robin
    Posts: 741 from 2003/2/24
    MOSSYS means MorphOS System ... it's by
    default sys:morphos/ ... this does not come with
    Ambient. It should be there from the beginning
    as it contains the MorphOS-Operating system.
  • »20.09.05 - 06:43
    Navigator
    Thanks for the help! If I wanted to remove
    Ambient, which directory's would I leave
    alone, and what line's should be commented
    out of the startup-sequence? I'm very familiar
    with Scalos, but if I understand correctly
    you cant run both and dont want to delete
    something that will make neither work.
    Navigator
  • »20.09.05 - 07:49
    aliem
    If you whant to start only Scalos just comment the "LoadWB" line in MOSSYS:S/startup-sequence
    and execute the Scalos's LoadWB
    Bye
  • »20.09.05 - 13:33
    Navigator
    Ok,thanks!
  • »20.09.05 - 15:21
    Navigator
    Since they both use LoadWB to activate them, how
    would I run Scalos from Ambient?
    Navigator
  • »21.09.05 - 08:53
    Bladerunner
    Posts: 418 from 2004/2/19
    luky-amiga:
    Well actually i would like to see old features come back ;-)
    For example the various effects for selected Icons. (I used to
    have blured Icons selected) I don` t understand why they where dissabled
    anyway. Where those really buggy? IIRC the where switched off because itix didn` t
    like them?! (Sorry Itix ;-) )
    And what about to fix this Icon Size thingy? yeah I know that with
    GPL Ambient, it was allready set to use a max size of 64x64 but imho
    that was just a temporary solution (Ambient crashed when using 128x128 Icon sizes)
    but it worked before, and it still works at least for a icon size of 96x96.
    I can think of some more things, but those are (at least for me) very annoying ;-)
    Don` t get me wrong, I like Ambient and I really prefer it over Scalos, nevertheless some
    things I don` t like.
  • »21.09.05 - 09:42
    klesterjr
    Posts: 196 from 2005/4/1
    Navigator
    I don't understand what benefit would be obtained from running Scalos from within Ambient -- Scalos works fine by itself.
    Just like Ambient, it has builtin PNG icon support, icon scaling, and thumbnail viewing PLUS it has a working def_icon system AND all the icon sorting options that were left out of Ambient.
    As I understand it, a def_icon system is in the works for Ambient -- so I'll keep trying it, but I don't think I'll ever be able to use it as my desktop until there is a way to turn off "auto-postioning" of icons.
    [ Edited by klesterjr on 2005/9/21 8:31 ]
  • »21.09.05 - 10:18
    kiero
    Posts: 129 from 2003/2/28
    I removed unlimited max size for icons because it was breaking layouting routines. It has nothing to do with sizes assigned to each size 'level'. If current max size is too small (is it?) we can make it bigger.
  • »21.09.05 - 10:18
    Bladerunner
    kiero:
    I can just mention what I noticed ;-)
    And that was it, one of the first Ambient GPL releases did
    crash badly when there was an Icon which was bigger then 64x64 in the root directory.
    When the limit was set to 64x64 it stopped crashing. I did then myself a compile
    where the max size was set to 128x128 again (as it was possible with the old Ambient Versions)
    And it did crash again. So I thought it "just" was a temporary solution, until that is fixed (A hint from
    Robin showed me that 96x96 doesn` t crash...)
    Anyway, yes 64x64 *is* to small ;-) I have several Icons which are bigger and are resized.
    I would be absolutley happy when i could have 128x128 back again ;-)
    (and perhaps those nice icon-select effects ;-) )
  • »21.09.05 - 11:42
    Robin
    @kiero
    Yes it is ;-)
    My fav sizes:
    #define SIZE_MICRO 24
    #define SIZE_SMALL 32
    #define SIZE_MEDIUM 48
    #define SIZE_LARGE 72
    #define SIZE_HUGE 96
    But in long term I would prefer if the user
    could set these values on the fly.
  • »21.09.05 - 12:02
    Robin
    @kiero
    btw, while we're talking about ambient probs.
    Is it possible to kill the current use of topaz font ?
    GNU:CVS/ambient2/ambient> grep topaz *
    Binary file Ambient matches
    boopsiviewclass.c: ta.ta_Name = "topaz.font";
    fonts.c: ta.ta_Name = "topaz.font";
    HISTORY:- default fonts switched from topaz to xhelvetica
  • »21.09.05 - 12:06
    kiero
    topaz.font is used as fallback font which is ALWAYS available (it's in ROM ie. boot.img). It's not default. Only used when opening of selected font failed.
  • »21.09.05 - 12:31
    Bladerunner
    Hu? How did I manage to doublepost that?! I guess I have to be more careful browsing with "links" ;-)
    (currently emerging KDE on Gentoo.. takes ages ;-) )
    [ Edited by Bladerunner on 2005/9/21 17:22 ]
  • »21.09.05 - 12:57
    luky-amiga
    Posts: 245 from 2003/5/1
    Bladerunner: Ok. You are right, I don't understand switching off "Selection effects" too. It's still possible to change source (config.h and makefile.objs) and use "Selection effects" (like blur effect) again. Maybe we should include this change in CVS sources, because I think it's great feature and who doesn't want this effects, he or she don't have to use them or can remove them from sources.
  • »21.09.05 - 13:36
    Posts: 1521 from 2003/2/24
    @Bladerunner
    Yeah I dropped icon effect prefs from Ambient. It is still possible have it by defining USE_DROP_EFFECT_PREFS on compile process. Maybe it could be reactivated again...
  • »21.09.05 - 13:48
    Posts: 1087 from 2003/3/24
    Yes it is
    My fav sizes:
    I totaly agree with Robin!!!
  • »21.09.05 - 17:14
