MorphOS Developer
Posts: 624 from 2003/2/24
Edit the code/morphos/Makefile, find:
LDFLAGS=-ldl -lm -noixemul
Remove -ldl and make it:
libdl isn't used at all, and it was left there accidently.
PS. As libdl is distributed with the new libnix, I'm pretty sure you're using the old one. If this is the case, I strongly suggest you upgrade your libnix. The latest libnix is available from MDC.
[ Edited by Piru on 2005/9/3 9:54 ]
