E-uae 0.8.28
    marcik
    Posts: 268 from 2003/4/12
    [Double post]
    [ Edited by marcik on 2005/8/2 10:25 ]
  • »02.08.05 - 07:25
    analogkid
    Posts: 711 from 2004/11/3
    is bsdsocketemu working under MorphOS ?
  • »02.08.05 - 07:27
    Norbi
    Posts: 99 from 2004/6/19
    double post
    [ Edited by Norbi on 2005/8/2 12:14 ]
  • »02.08.05 - 09:10
    Norbi
    Not yet. Maybe next version uae.
    Mounting hardfile it's possible.
    I write in .uaerc :
    hardfile2=rw,dh3:/system.hdf,32,1,2,512,0
    It's works, but very slowly.
    My version e-uae is:
    "E-UAE 0.8.28-CVS
    Build date: Jul 26 2005 20:03:50"
  • »02.08.05 - 09:11
    magnetic
    Posts: 2129 from 2003/3/1
    Hi guys
    I opened up a thread requesting an MOS bounty for UAE. Please post comments there if you can.  8-)
    magnetic
  • »02.08.05 - 15:48
    klapdeur
    Posts: 132 from 2003/6/28
    hi fab how does the frameskip function work in e-uae the version
    youve released??
  • »10.08.05 - 13:20
    serge
    Posts: 725 from 2003/2/20
    I write in .uaerc :
    "E-UAE 0.8.28-CVS
    It's faster mounting a drawer.
    I did this:
    filesystem=rw,workbench:data:workbench
    filesystem=rw,HD-Games:data:HD-Games
    filesystem=rw,Applications:data:Applications
  • »10.08.05 - 13:47
    Posts: 168 from 2004/11/18
    just
    gfx_framerate=3
  • »10.08.05 - 17:08
    serge
    Here is what I found on the configuration texte file from E-UAE 0.8.27
    gfx_framerate=<n> (default=1)
    Specifies the rate at which display frames are rendered when emulating
    graphics output from the Amiga chipset. <n> can be a number between 1 and
    20, where 1 means that every display frame is rendered and 20 means only 1
    in every 20 frames is rendered.
    Increasing <n> increases the speed of emulation (there's less work to
    do), but decreases the quality of the display output.
    For example, when emulating a PAL display (50 Hz), for full-quality output
    (gfx_framerate=1), E-UAE must update its display 50 times a
    second. Setting gfx_framerate=4 will cause E-UAE to draw only 1
    frame in 4 and thus its display will updated only 12.5 times a second.
  • »11.08.05 - 10:47
