Live-CD "CD Ga" WIP
    Jupp3
    Posts: 1193 from 2003/2/24
    uncompressed it'll be at about 700MB :( )
    I like when this kind of CD's are full, and "there's no valuable space wasted" :-)
  • »12.07.05 - 17:33
    Robin
    Posts: 741 from 2003/2/24
    CDGA.iso is up @ pegasos.org :-)
  • »13.07.05 - 07:24
    gunne
    Posts: 441 from 2003/2/25
    Hello,
    Yes, its up now as torrent, hopefully it works fine, and that it will be more that share/seed it later on.
    frostwork,
    Yes, played with the cd little bit yesterday evening. Unfortunately the TFT monitor cant show the frequenzy thats in the game menu... Tested with two different TFT's. The boot and bootsplash screen works on the TFT without problem, and the bootsplash looks very nice.
    However it worked great on my TV, so played pinball for a little while :-)
    And a very nice game cd !
    Will see if I can take a look on this with frequency for the TFT, as I think it perhaps is many people that uses TFT monitors. TFT are usually little more sensitive when it comes to this with frequenzies then CRT's, and will come out of range if to high frequenzie = no picture.
    Gunne
    [ Edited by gunne on 2005/7/13 12:04 ]
    Best wishes, Gunne
  • »13.07.05 - 09:02
    Robin
    @gunne
    Yes, the download works fine :-)
    I'll keep on seeding it on my server,too.
  • »13.07.05 - 09:26
    cbrxx1100
    Posts: 22 from 2005/3/18
    Hi everyone!
    First of all i would like to thank frostwork for his work which gives
    time extension and hope to Morphos users. In any case i could help
    with anything (unfortunately my programme skills are very limmited but
    i have some expirience on amiga systems, i am using amiga since
    FOREVER!).
    Now can you please tell me where i can find your first work?
    Best regards,
    George
  • »13.07.05 - 10:35
    Robin
    Are you looking for the cd32-torrent ?
    http://www.ggsdata.se/Bilder/cd32-live.torrent
  • »13.07.05 - 12:49
    Frostwork
    Posts: 302 from 2003/4/18
    Hi!
    Nice "cd ga" is available! :)
    My "main" system is a debian sarge, but a of missing net on peg
    i install all packages manually or simply compile from sources
    (probably a very wild system, but everything works till now)
    The livecds are a mix between gentoo/debian/source, but are
    built via chrooted gentoo...
    have much fun! :)
    frostwork
  • »14.07.05 - 08:50
    igracki
    Posts: 469 from 2003/2/24
    does it work on Peg1 too?
    I'm currently downloading it, but I only have
    6-14KB/s;-((((
    If its not working on Peg1 I could abort the download.
  • »14.07.05 - 17:33
    marcik
    Posts: 268 from 2003/4/12
    It's great! :-) Thanks for your work! :-)
  • »14.07.05 - 17:47
    SoundSquare
    Posts: 1214 from 2004/12/1
    is it possible to edit the Xorg config file in order to tune it for "out of range" screens and reburn the CD?
  • »15.07.05 - 05:58
    Frostwork
    Hi!
    @ igracki:
    No idea! Before it was released I asked if s.o. could check if the kernel
    boots on peg1. Nobody wanted to so I'm sorry I can't help you...
    @marcik:
    Thank you! :)
    @SoundSquare:
    Mhh, good question! I wanted to symlink the xorg.cfg into (the extracted) cfg.tar.gz, but I'm not sure if I did so...
    If I didn't and you have an installed linux you could still do
    "the hard way":
    - mount cdga.img with
    "mount -t squashfs /path/to/cdga/.img /mount/point - o loop"
    - copy all into workdir
    - alter workdir/etc/xorg.cfg
    - mksquashfs /workdir /path/to/new/cdga.img
    - use the new one (I hope the mksquashfs commandline above
    is correct ;) )
    cheers
    frostwork
  • »15.07.05 - 16:13
    SoundSquare
    @frostwork
    nice ! i'll do that as soon as my Gentoo installation will be complete (still compiling...)
    cheers m8
  • »16.07.05 - 07:16
    Mario
    Posts: 46 from 2003/4/27
    HI frostwork!!
    I have downloaded and tested GA livecd!
    It works perfectly on my PEG II with ATI radeon 9250 256 MB.
    Thank you for your great job again.
    I hope, meanwhile, you have received my luminocity liveDVD.
    Bye
    Mario
  • »23.07.05 - 13:09
    Frostwork
    Hi :)
    You didn't get my PMs? I even wrote 2... :)
    Great to hear cd ga works for you :)
    Luminocity works very good, too :)
    cheers
    frostwork
    [ Edited by Frostwork on 2005/7/24 17:10 ]
  • »24.07.05 - 14:10
