MUI 4.0(!)
    Posts: 2730 from 2003/2/24
    Check out the alpha snapshot of MUI4 HERE! :-D
  • »14.07.05 - 15:37
    pegasosuser
    Posts: 138 from 2004/4/9
    good! i need that!
    i have installed and working good!
    greetings Cor van Londen.
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »14.07.05 - 15:57
    analogkid
    Posts: 720 from 2004/11/3
    hmm, Ambient panel doesn't work anymore :(
  • »14.07.05 - 16:06
    SoundSquare
    Posts: 1214 from 2004/12/1
    Fab1 released an ambient version that fixes the issue with panels and MUI4
    http://perso.wanadoo.fr/fabien.coeurjoly/ambient.lha
  • »15.07.05 - 05:30
    Posts: 1087 from 2003/3/24
    Wow i like MUI 4.0!
    Only 2 things could be better, the ASL Requesters could save position and size and the list displays the last Dir and the first File instead of starting with Dir first.
  • »15.07.05 - 08:16
    Posts: 1932 from 2003/10/19
    Its not bad, I tried the ambient that foxes the panels as well and it looks good. I decided to get rid of it because I dont like the beta nag screen you get every time you reboot.
  • »15.07.05 - 09:26
    bigfoot
    Posts: 510 from 2003/4/11
    Type setenv save i_know_mui_is_beta in a shell to get rid of that requester
  • »15.07.05 - 09:30
    I typed it in the Shell without success.
    Where do i have to type it?
    Checkout MUI4 in Action!
  • »15.07.05 - 10:49
    marcik
    Posts: 268 from 2003/4/12
    It should be:
    setenv save I_KNOW_MUI_IS_BETA 1
    And if this still doesn't work just create textfile named I_KNOW_MUI_IS_BETA in ENVARC: containing "1" :-)
  • »15.07.05 - 10:56
    Chain-Q
    Posts: 350 from 2003/10/12
    The correct line is:
    setenv save i_know_mui_is_beta 1
    (Note the 1 at the end of line.) Just tested, works for me.
    [.Hosting AmigaSpirit.hu.]
  • »15.07.05 - 10:56
    bigfoot
    Ah well, here the file is empty, and that works for me. Stuntzi must have fucked it up :)
  • »15.07.05 - 11:46
    bigfoot
    Yikes, I just realised that setenv doesn't set an empty variable, that's why it didn't work. Sorry, guys, so setenv save i_know_mui_is_beta 1 or whatever will do :)
  • »15.07.05 - 11:48
    Jupp3
    Posts: 1193 from 2003/2/24
    muigfx-drawer MUST be copied to MOSSYS:prefs/
    It doesn't seem to work from SYS:prefs/
  • »15.07.05 - 12:52
    Posts: 62 from 2004/9/8
    Just one question: I have installed MUI4 on my system... but MUI4
    don't work at home :(
    Just after the window "MUI reminder", I have a new window with "MUI4
    don't create class listviewlist. This souldn't happen. contact
    support".
    Why ?? Is there a solution for my problem, please ??
    PegasosII G4 512Mo 80Go ATI RADEON 9200SE....
    Yeah! The best it's MorphOS :)
  • »15.07.05 - 15:09
    ok... sorry! forget my last question :) MUI4 works fine here now :)
  • »15.07.05 - 15:49
    Frostwork
    Posts: 302 from 2003/4/18
    Hi!
    Thanks for MUI4 beta!
    Thanks for patched ambient-cvs!
    Thanks for env-var !
    cheers
    frostwork
  • »15.07.05 - 16:46
    hnl_dk
    Posts: 47 from 2004/3/19
    @bigfoot
    Shouldn't have have been i_know_mui_is_alpha ;-)
    Best regards,
    hnl_dk - Henning Nielsen Lund
  • »15.07.05 - 21:57
    Furvert
    Posts: 83 from 2004/4/20
    I don't know about the new MUI but it looks like the Ambient that is needed for this messes up Pixel32. It's causes a weird error when you click Pixel (Not really sure how to explain it but it rescans the directory and then the program thinks the registration is invalid. Even if you revalidate your code. :P
  • »18.07.05 - 23:06
