Experimental rtgmaster for MorphOS
    Posts: 1521 from 2003/2/24
    Yo
    I wrote today and yesterday an experimental rtgmaster.library replacement for MorphOS. It is not complete but seems to work more or less. WarpUp support is problematic because of MUI screen requester issue but maybe it works for someone...
    rtgmaster.lha (13kB)
    You are guaranteed to get issues and I'd like to get your input. I couldnt find many free games using rtgmaster (in fact only one: AThrust 68k which works).
  • »14.06.05 - 18:31
    zukow
    Posts: 658 from 2005/2/9
    thx Itix, AB3d_tkg rtg 3d engine is working (menu is invisible )
  • »14.06.05 - 18:56
    bigfoot
    Posts: 510 from 2003/4/11
    I hope that one day, Napalm will be possible to play on MorphOS
    It already is. It runs fine on MorphOS on my A1200 ;)
    Unfortunately Napalm does a lot of hardware banging, so getting it running on the Pegasos might be a slightly bigger task.
  • »14.06.05 - 20:16
    Posts: 979 from 2003/6/28
    The most waited stuff for classic amigas, MorphOS, I hope someday is released and more developers doing stuff...
    Maybe some people can donate rtgmaster games to itix ;)
    ab3dII is freeware, no?
  • »14.06.05 - 23:02
    MarK
    Posts: 641 from 2004/1/25
    and how about to make it more uptodate... and support 16/24/32 bit modes? i guess, it's really needed with morphos... and to make it working also in window...
    bye, MarK.
  • »15.06.05 - 04:01
    Crumb
    Posts: 737 from 2003/2/24
    "Abuse" used RTGMaster.
  • »15.06.05 - 06:26
    @timofonic
    AB3d II sources are at aminet IIRC but it is just sources. No use.
    @Crumb
    Got from Aminet but it seem to be shareware and misses datafiles. I found Abuse demo for PC but I cant unpack data files...
    @MarK
    It is planned but one step at a time. I just got WarpUp stuff running too... More to come.
  • »15.06.05 - 09:08
    Posts: 1932 from 2003/10/19
    Itix, great work! Please keep it up! It is a welcomed lib thats for sure!
  • »15.06.05 - 09:43
    Frostwork
    Posts: 302 from 2003/4/18
    Hi :)
    Abuse-datafiles can be freely downloaded from the abuse-sdl
    homepage :
    http://www.labyrinth.net.au/~trandor/abuse/
    cheers
    frostwork
  • »15.06.05 - 10:38
    hooligan
    Posts: 1948 from 2003/2/23
    AFAIR Abuse has always worked
  • »15.06.05 - 13:44
    Schlonz
    Posts: 131 from 2004/4/16
    Yeah, Abuse did work always, but without sound... as far as I know Abuse used a special feature of AHI V4 which was removed in AHI V5 so there is no sound in AHI versions beyond V4.
  • »15.06.05 - 16:33
    Ok, I've updated rtgmaster little and it works better now. WarpUp programs work now and many rtg functions were corrected. Abuse works, AThrust (68k and WUP) works, AB3D II is "usable".
    Download: rtgmaster r2 (15K)
    And yes, no sound in Abuse.
    Oh and btw thanx for link, frostwork.
    [ Edited by itix on 2005/6/15 21:41 ]
    [ Edited by itix on 2005/6/15 22:33 ]
  • »15.06.05 - 17:39
    killlbilll
    Posts: 95 from 2004/5/19
    You could also try warpHexen, WolfPac, and other WarpOs ports by S. Hausser from aminet.
    Btw: Good work  8-)
    [ pegasos ii / g4 | morphos1.4.4 ]
  • »16.06.05 - 06:42
