BasiliskII and OS4Emu update
    Posts: 1520 from 2003/2/24
    I've released new BasiliskII 0.9.2 for MorphOS:
    BasiliskII.lha (470K)
    BasiliskII-src.lha (800K)
    Changes in Basilisk 0.9.2 MorphOS version:
    * Can create hardfiles in GUI
    * Can quit emulator at anytime ("emergency quit")
    * Optimized speed
    * Added frameskip option
    There is also small fix for OS4Emu 1.7:
    Since our #az webmaster is MIA it is available from my homepage
    os4emu-update.lha (5K)
    This fixes issues in ELF loader.
    That is all for now. I'm off to sauna, cu in Monday :-)
  • »10.06.05 - 09:26
    Wishmaster
    Posts: 342 from 2003/6/29
    thx.
    I'm running Maple on Basilisk.
    Pegasos PPC
  • »10.06.05 - 09:29
    Posts: 2070 from 2003/6/4
    You're saunaing the whole weekend? Man, you're really *hot*!
  • »10.06.05 - 09:30
  • deb
    deb
    Posts: 76 from 2004/11/17
    With the frameskip option Basilisk is now much faster but it still have color problems with 8bit full-screen mode:-(
    Is it now possible to install MacOS 8?
    Your work is much appreciated itix, thanks man.
    [ Edited by deb on 2005/6/10 15:03 ]
  • »10.06.05 - 10:29
    I wonder what that color problem could be... because here colours seem to be just fine. :-?
    MacOS 8 doesnt work still. It just hits endlessly somewhere in the CPU emulation code. I suspect something is not patched properly in MacROM code but fixing this is beyond my skills. Or maybe it is a bug in UAE's CPU emulation. Impossible to know. Sometimes MacOS 7.x mode hits too at system init phase but not always.
    Merging MorphOS code by BasiliskII 1.0 code could fix some problems. 0.9.2 already got some code from 1.0 fork but final merging is tedious job.
  • »12.06.05 - 20:58
    Schlonz
    Posts: 131 from 2004/4/16
    Great job, itix. I especially like that I can now create hardfiles from the gui.
    V 0.9.2 does not like my original OS 8 CD anymore... V 0.9.1 did like it, but the new version keeps telling me that the CD is write protected. Hm...
  • »12.06.05 - 21:11
  • deb
    deb
    @itix
    It's more of a palette problem which I have from the first release, it looks like colors which have to be white are black and the black ones are white.
    This problem only exists in 8bit full-screen mode not in 24bit or windowed mode.
    I did try to solve the problem by,
    * Test different Mac-rom versions
    * Replace my Radeon 8500LE with 9000Pro, Voodoo 5000 and 4500
    * Replace Radeon monitor driver and cgxvideo.library with ones from MOS 1.4.2
    Nothing did help :-(
    [ Edited by deb on 2005/6/13 9:33 ]
  • »13.06.05 - 06:31
    analogkid
    Posts: 706 from 2004/11/3
    what about making a compatiblity list of working Mac ROMs ?
  • »13.06.05 - 06:50
    Chain-Q
    Posts: 350 from 2003/10/12
    I haven't installed OS4Emu 1.7 until now. But i did it now, including the update, and tried Zero by Universe again, because according to the readme, P96 emulation is now fixed, to avoid buggy colours (wrong endianness). But the demo still has "reversed" colours, with wrong byteorder here, just like with previous OS4Emu. I've 1.4.5, Voodoo4/4500 PCI. Hints?
    [.Hosting AmigaSpirit.hu.]
  • »14.06.05 - 09:20
  • deb
    deb
    Ok, here is a list of some working Mac-ROMs which I have tested with Basilisk II
    v124.19 Mac LC-I
    v124.25 Mac LC-II
    v124.34 Mac LC-III and Performa-450
    v124.50 Mac Performa-630
    v124.35 Mac Quadra-650
    v124.38 Mac Quadra-605
    v124.21 Mac Quadra-700 and 900
  • »14.06.05 - 14:19
    @Chain-Q
    You probably lack suitable 16bit display mode. It is quite difficult to remember after so many months but I recall Zero assumes little endian hicolor screen. IIRC in real OS4 all screen modes are always byte swapped but in MOS this is somewhat random.
  • »14.06.05 - 18:24
    Posts: 979 from 2003/6/28
    It could be nice use Basilik II as base. What about including MorphOS code into the Basilik II 1.0 CVS?
  • »15.06.05 - 08:17
    @timofonic
    It is my intention to do so but it needs lot of manual adjusting. Internals of Basilisk II have changed etc etc.
  • »15.06.05 - 08:55
    zukow
    Posts: 650 from 2005/2/9
    What about adding Warp3d.library interface to Os4emu
  • »15.06.05 - 15:17
