Hi people, i've got some questions about FPSE, because it is not working good... i've got g3/600,Voodoo3 and the latest osemu1.7 (or at least i hope it's 1.7 because version command reports that it is 1.6)
I tried several versions downloaded from www.amidog.com :
OS4revision3
I haven't managed to launch the program at all!!! It complains about failing to open gpupete.dll, which of course is located in plugin directory. This is something which always makes me mad : a program tells me it doesn't have something but IT IS THERE!!!
OS4revision2
This one is working. I tested FIFA2002 originalCD, it loads succesfully but it is unplayably slow. Maybe continuous reading from the disc during the game slows it down? i created an iso image of the cd in MakeCD but when i load it into FPSE, it reports about some weird "bad hankaku code" and fails to start. I also tested WRC rally original, the starting animation is played at good speed, but no sound is heard and when the screen with language selection appears, no key is active and i have to exit Also, when I exit from it, the shell output ends with "remove sound" message, cpu usage stays at maximum and i have to reboot.
FPSE for Amiga and WarpOS
This one is loading data from CD much slower, and has got some graphic bugs so the screen is broken and fpse freezes.
So please, help me if u can
pecaN of the Czech PowerPC User Group
