trackdisk.device
    Posts: 408 from 2004/7/15
    There is one good and one bad news about trackdisk.device
    1. Good one. It works! Really works! Now you can mount 1.44" FAT diskette to be able to read it. Writing and formatting are not tested yet. But at least writing should also work (can be attempted after resolving (2)).
    2. Bad one. If you try to copy some file by small chunks (like Directory Opus 4 does, it uses 4kb buffer), the file will be corrupted. If the file is rather large (about 800 kb) the whole memory will be trashed and system will heavily crash. "CheckDisk" utility from Aminet which reads sector-by-sector into 512 bytes buffer works fine. I think the problem appears only during large data transfers. Disk directory is always read fine (volume is mounted).
    A help is needed in order to find the reason for (2). So i invite everyone who is interested.
    The source code can be found at http://sourceforge.net/projects/unmorphos, it is not released yet so download it from the CVS. You can ask me for developer access if you wish to contribute to the project.
    P.S. Writing routines are not tested so protect your floppies from writing for now during testing.
    P.P.S. The driver uses 100% of the CPU while actually reading/writing data and runs at a high priority in order to avoid data loss, so it breaks multitasking a bit. Not fixable because there is no public interface for ISA interrupts in MorphOS. Bug MOS team, not me for this.
    iPod, iBook, iMac,... iRobot?
  • »24.05.05 - 04:04
    vovka
    Posts: 24 from 2004/5/9
    MorphOS will get fdd support!
    the last from all os!  :-P
  • »24.05.05 - 04:46
    Posts: 1932 from 2003/10/19
    I guess its a nice thing to have for some, but I fail to see the point in this age. USB drives work perfectly here using fat95. I can format and do anything I want with them. I dont even have a flopy drive anymore in ANY of my computers. I tend to use a 1GB USB flash stick in place of them now, or even a CD-R.
    Thanks for a new project though, I am sure several people wil enjoy it once its working and safe to use.
  • »24.05.05 - 09:30
    analogkid
    Posts: 722 from 2004/11/3
    I think it's good for data exchange with computers (like my A500), who has only a floppy drive.
  • »24.05.05 - 09:51
    Miky060
    Posts: 694 from 2003/2/24
    No analogkid, I do not think. It will be able to read PC formatted disks, not amiga ones, so it will not htelp you.
    Sonic, correct me if I am wrong.
  • »24.05.05 - 12:32
    Golem
    Posts: 766 from 2003/2/28
    The A500 will do that too :)
  • »24.05.05 - 12:44
    analogkid
    you're right, the peg won't be able to read amiga disks, but the amiga will be able to read pc floppys :)
  • »24.05.05 - 14:04
    Kamul
    Posts: 121 from 2004/6/9
    I'm afraid I don't share your view. I don't use floppy disk very often, but I really needed it a few times for example to read some data saved on FD on the university. I was unable to send them by the internet or save them on USB device because I was working on very old PCs. They were used to control some technical proceses, for example.
    Besides, my FD drive sits in my Peg unused, and I don't like that. ;)
    So, thank you Sonic for you work and good luck!
  • »24.05.05 - 14:33
    Dont get we wrong, I think its a nice thing to have. I just find a CD is a better option in this day, Most computers have at least a normal CD-ROM and can read a CD-R just fine. They are cheap now, even less then a 1.44 disk.
    When this matures I may even put in a 1.44 drive who knows.
  • »24.05.05 - 15:57
    Piru
    Posts: 624 from 2003/2/24
    Hmm, shouldn't the device be called mfm.device?
  • »25.05.05 - 11:44
    Hmmm... Good question. There can be both opinions and both are correct. In AROS it is called trackdisk.device, the name is inherited together with the code.
    Well, it's easy to change if someone insists. I won't resist.
    But, in future it will probably implement much more functionality than mfm.device. mfm.device is strictly limited by 512 bytes/sector geometry. trackdisk.device will probably identify the geometry of every new disk and will be able to work with for example ZX-Spectrum disks. If there'll be requests...
  • »26.05.05 - 05:28
