Latest Ambient release!
    Posts: 1087 from 2003/3/24
    On the Aliem Projects Page you can find the latest release of Ambient!
    I have one question what is the corect commandline to type in OF to run that Version properly?
  • »24.04.05 - 08:26
    MaSC
    Posts: 63 from 2003/12/1
    try:
    setenv boot-file boot.img ramdebug edebugflags="logkprintf"
    then type boot
    [ Edited by MaSC on 2005/4/24 5:12 ]
  • »24.04.05 - 09:11
    Posts: 1521 from 2003/2/24
    It means you are recommended to use ramdebug if you use this version. I.e. I use "boot /pci/ide/disk@0,1:0 boot2.img ramdebug".
    The CVS version was enabled with debug and dumps lot of debug information to the serial which slows down everything. Ramdebug redirects serial output to the RAM buffer which is much faster. (Getramdebuglog can be used to retrieve debug log from ram.)
  • »24.04.05 - 09:12
    Sprocki
    Posts: 132 from 2005/2/23
    I realized over the last about two or three weeks that debugging was enabled from one day to another and looked for the switch to disable it both in the makefile and the source itself. Although I read the makefile as if a releasedir ambient_release should be build I couldn't get one. Setting the switch in line 12 of config.h to zero didn't help either. How can I disable building a debug version or at least build both versions from the same make?
  • »24.04.05 - 09:39
    aliem
    Posts: 85 from 2003/12/11
    Please, don't call my compiles "release".These are only unfinished and temporary CVS Snapshots; these compiles are good to know how good the Ambient team is working.
    Bye
    Thanks to Zapek and the whole Ambient Team.
  • »24.04.05 - 16:36
    ossian1961
    Posts: 123 from 2004/7/31
    @Aliem
    I found it very good and quite stable. Good work! Is there some possibility to extend the panel feature like grown up icons mouse over or center the panel and alpha background?
    bye, Ossian1961 :-D
    [ Edited by ossian1961 on 2005/4/24 16:09 ]
  • »24.04.05 - 18:25
    aliem
    Please use Feature Request at sourceforge.net.
    Bye
  • »24.04.05 - 19:26
    Is this CVS compile much slower, with the setenv variable set, then the old ones?
  • »24.04.05 - 19:28
    I have installed the latest Ambient Version and set the Env variable. And it works great, MOS seems to be faster then befor! :-D
  • »25.04.05 - 08:12
    amigafil
    Posts: 23 from 2003/9/6
    hello,
    What set the Env variable ?
    Powerbook and Pegasos II G4 MOS 3.7  :-)
  • »25.04.05 - 08:42
    serge
    Posts: 725 from 2003/2/20
    @ Aliem
    I'm afraid  :-o
    cant acces your web site
    http://projects.morphwiki.org/
    Would like to download your Ambient compilation.
    Thanks
  • »25.04.05 - 08:44
    You can find the Env variable in the second post in this thread.
  • »25.04.05 - 14:22
