Bakcground and font coulor for AmbientShell
    serge
    Posts: 725 from 2003/2/20
    In some screen grabs, we can see a variety of background coulors and
    fots diferent for AmbientShell.
    Which are the parameters to change them please?
  • »10.06.04 - 07:51
    hooligan
    Posts: 1948 from 2003/2/23
    AFAIK you can do it by placing standard ANSI-codes into Shell-Startup, for example.
  • »10.06.04 - 08:17
    hiTCH-HiKER
    Posts: 172 from 2003/12/31
    Is there a way to prevent a black shell to become grey again when
    doing iconify/uniconify?
  • »10.06.04 - 08:23
    DoctorMorbius_FP
    Posts: 315 from 2004/2/13
    No way. But the problem is already solved in MorphOS 1.5 shell.
    In February Nicolas Sallin suggested me (on the beta2 mailing list) to create and use some configuration files for CON:, but they don't work because they are tied to something new we don't have in MorphOS 1.4.2. We must be patient.
    In the meanwhile I've solved the problem with an alias. This was what I inserted in the shell-startup:
    Alias setsc Echo "*E[0;0;0;0V*E[1;220;220;220V*E[...*Ec" NoLine
    When the shell returns to the original colors, I type "setsc" and they are reset as I want. If you need the previous lines, scroll the history bar, or else remove the final *Ec part from the alias, and the display will not reset automatically.
    Regards.
  • »10.06.04 - 11:42
    Henes
    Posts: 507 from 2003/6/14
    What I told you also works in MorphOS1.4
  • »10.06.04 - 12:00
    Posts: 43 from 2003/9/1
    This will turn your Ambient Shell into ANSI color mode. Simply cut/paste into s:color-startup and execute it whenever you want or add it to s:shell-startup.
    ;--- Begin s:color-startup ---
    echo "*E[0;000;000;000V" ; black
    echo "*E[1;255;255;255V" ; white
    echo "*E[2;000;255;000V" ; green
    echo "*E[3;255;255;000V" ; yellow
    echo "*E[4;000;000;255V" ; blue
    echo "*E[5;255;000;255V" ; magenta
    echo "*E[6;000;255;255V" ; cyan
    echo "*E[7;255;000;000V" ; red
    ;--- End s:color-startup ---
  • »10.06.04 - 12:17
    jdryyz
    Posts: 127 from 2004/4/9
    I have a related question-- how does one save the window location/size of the shell? I tried using shapsnot, I believe, but no go.
    At present, the New Shell command launches a window that fills my entire screen.
  • »10.06.04 - 13:32
    cecilia
    Posts: 459 from 2003/8/30
    back about 100 years ago when i did something like this on my amiga shell, i added some stuff in the icon.
    now, this is from memory, but it looks something like this:
    WINDOW=CON:0/50//130/cecilia's Shell/CLOSE
    if it blows up, don't blame me!  :-P
  • »10.06.04 - 13:39
    DoctorMorbius_FP
  • »10.06.04 - 13:40
    jdryyz
    Thanks, Cecilia. It is coming back to me now. I believe I modified a shell icon back in earlier days. I may not be able to make these settings stick in a global manner.
  • »10.06.04 - 16:48
  • Leo
    Leo
    Posts: 428 from 2003/8/18
    To permantely change CON: colors, you may do:
    1. Create a file 'envarc:con.prefs' and add to it:
    //////INIT con.init
    (I guess you may also add default sizes, title, window gadgets,... much like when calling "newshell from con:150/200/200/300/MyTitle/CLOSE...")
    2. Create a file 'envarc:con.init' and add to it your color escape sequences
    Should be ok...
    Leo.
  • »06.04.05 - 20:03
    Aaron
    Posts: 127 from 2003/6/14
    You could install MUIcon and set your colors in MUIprefs and get other great features too.
    --Aaron
    --Aaron Diezman
  • »06.04.05 - 22:44
