Posts: 2728 from 2003/2/24
Jupp3 wrote:
I'd recommend Pegasos 1 only if you get one with April 2 and memory, and you get it for a cheap price.
(Memory for Pegasos 1 is MUCH more expensive than memory for Pegasos 2)
I would not recommend a Pegasos1 to anyone. Sure, they may work, but the Pegasos2 is so much better and it is still supported. If you get a Peg1 for free, then OK, but I would *still* recommend getting a Peg2 also!
@ wasisme
MorphOS currently only comes bundled with the Pegasos computer. Choose a dealer close to you from this page (or click "Enter Here" in the right row to get to Genesi's own webstore):
http://www.pegasosppc.com/purchase.phpIf you buy a pre-built system (like a Pegasos Open Desktop Workstation (ODW) or something the dealer has put together), then you will most certainly get MorphOS pre-installed as well as a CD. If you buy a motherboard only then there is of course no way to pre-install the OS so you will get the CD only!
MorphOS is Amiga
done right!
MorphOS NG will be AROS
done right!
