FreeSpace Q's.
    td741
    Posts: 224 from 2003/4/2
    Okay... Picked up Freespace a few nights ago and attempted to use it.
    I've got it installed, I've updated it to the first PPC update and the Beta2 update that was released yesterday(?!).
    I configured it to use the software renderer, AHI, disabled the streaming music but kept the streaming voice. Updated the "buffers" as well.
    I sometimes get the program to freeze up on the briefing and debriefing. The videos also don't work. I do have FroggerNG regsitered and the most recent update does say that I could configure it to use an external video player with a command line option. Has anyone managed to get Freespace to use Frogger yet?
    Anyone have any tricks that I could use in order to get it to not freeze on briefing/debriefings? :P
    Steph
  • »23.05.03 - 12:57
    Posts: 1074 from 2003/3/24
    It frezes because of the streaming voice AFAIK.
  • »23.05.03 - 14:06
    td741
    I was afraid of that... :( I guess I'll disable the streaming voice and see what happens next.
    Steph
  • »23.05.03 - 14:11
    Henri
    Posts: 73 from 2003/5/14
    Yes, me. :)
    Use the latest FreespacePPC-beta (as You wrote).
    Edit the file "Freespace.prefs" and add the following
    (I would prefer the next line after "VideoDir"):
    VideoPlayer = YourPath:FroggerNG/FroggerNG.MOS AUTOSTART AUTOEXIT FS DEPTH 24
    Regards
    BTW: Anims are best played (screen-ratio) on a 640*480 screen.
    You could set this with Frogger, if it doesn't use it automatically,
    because if You have something like 640*400 or lesser definded as
    screenmode Frogger/CGX will use this. In that case
    use MODEID xxxxxx, where You've to fill in the decimal
    or hexadecimal value for You 640*480*24 mode.
    (use GetHexModeID from AmiNet).
    An example:
    YourPath:FroggerNG/FroggerNG.MOS AUTOSTART AUTOEXIT FS DEPTH 24 MODEID 1083310161
    or as hexadecimal:
    YourPath:FroggerNG/FroggerNG.MOS AUTOSTART AUTOEXIT FS DEPTH 24 MODEID 0x40920051
  • »13.06.03 - 09:21
    td741
    AWESOME... Thanks.
    I just tried it out and I'm getting videos playing great with Frogger!
    I wonder if we'll ever get streaming music and voice setup? :P
    Steph
  • »15.06.03 - 00:58
    Posts: 906 from 2004/1/24
    Hmmm,
    Having a voodoo3, i'm using the warp3d driver. Alas, freespace radomly hangs within the missions (when flying). I tried the official update, but that hangs when entering the briefing room. Then I tried the beta-update, but that one hangs when entering the game (standing in the main hangar).
    Help/suggestions anyone?
  • »31.07.04 - 12:02
    Aaaargh!
    For some reason it hangs everytime now, some 10 seconds after entering mission 2!!!! I tried various warp3d settings, but nothing seems to help -> software rendering gives me a bugged display, even though it's configured correctly in the system prefs.
    If there's someone with a working Freespace install, please enlighten me; it's incredibly frustrating having finally bought the game only to discover that it won't work!
    Thanx in advance!
  • »01.08.04 - 12:56
    Jupp3
    Posts: 1193 from 2003/2/24
    I've played Freespace a bit on my Pegasos too, and it sure feels as unstabile as it was on my amiga...
    Maybe disabling sounds helps with the newest update?
  • »01.08.04 - 16:37
    Posts: 1932 from 2003/10/19
    I've tried to play it and cant even get it to start. Once its installed (I have to install it to my system partition (It has some bug that tells me I have negative HD space on my work drive) I run the setup app and then hit play. It gives me an erroe telling me freespace.exe is not executable. Cant figure it out.
  • »01.08.04 - 16:44
    Posts: 979 from 2003/6/28
    Where is the source code of Freespace? I cant find it
    And what about Freespace 2? It has source code available:
    http://www.freespace-2.com/ddn/
    http://freespace.volitionwatch.com/fsscp/
    http://fs2source.warpcore.org/cgi-bin/cvsweb/cvsweb.cgi/
    And a mod that i found:
    http://www.3dap.com/hlp/hosted/babylon/faq.shtml
    The parts of Freespace 1 runs on Freespace 2 then?
    Edited: icculus' source code supports FS1 & FS2, so i think that the others of CVS will suppor it...
    [ Edited by timofonic on 2004/8/2 8:51 ]
  • »02.08.04 - 04:45
    Bladerunner
    Posts: 418 from 2004/2/19
    Hi Freespace Fans
    Sorry to bring up this old thread but I had to, as it seems as I found a solution for the bad crashes in Freespace.
    It happend also to me, that after the update Freespace refused to work (i.e. it crashed badly) Now I tried to use the 68k Version from Freespace and now it seems to work pretty well :-) Don`t worry about the Emulation, it is still pretty fast, even if it is Softwarerender. (I excpected that this Version won`t run without 3d Hardware Suport, but well... ;-) )
    Oh and another hint: If you have an usb Joypad with analog Stick, try to configure this Stick as "Mouse" et voila, you can play Freespace with an analog Stick ;-) (Just have to figure some good values for smoother moving)
    BTW, wasn`t there something about Freespace 2 port for MOS recently?!
  • »27.03.05 - 15:02
