MOS 1.4.2
    matt3
    Posts: 784 from 2004/2/10
    How do you know you are running 1.4.2? If your not how would you download it?
    Thanks,
    Matt
  • »19.01.05 - 10:38
    AyoS
    Posts: 410 from 2003/8/13
    from the download site, which I believe is unavailable at the moment...
    do you have the cd image??
  • »19.01.05 - 11:36
    DSLCC
    Posts: 246 from 2003/5/14
    I downloaded all the MOS stuff from the zargos ftp site 2 days ago in anticipation that it would not be there for long.
    Pegasos 1 G3 MorphOS 1.4.5* Mac G4 Sawtooth 1Ghz Tiger 10.4.1* Both Rock! :-D
  • »19.01.05 - 12:01
    AyoS
    Then I stand corrected, I had tried accessing the site about 2 weeks ago and it was not available, maybe it is still up? If so Good.
    @matt3 if the Zargos site is still up you can get 1.4.2 + other software thru it.
  • »19.01.05 - 12:06
    DSLCC
    Just checked it now...it's still up.
  • »19.01.05 - 12:16
    matt3
    How do you get access to it?
    Thanks!
    Matt
  • »21.01.05 - 15:16
    Posts: 34 from 2004/4/8
    Register your Pegasos in the known way, and you get the Zargos account. It is work for me, but its about one year ago. BTW Zargos is still working.
  • »21.01.05 - 16:13
    Kamul
    Posts: 121 from 2004/6/9
    Could you give me address for this server? I was trying to connect many times, but with no success. I used address, login and password exactly the same as half year ago, when it worked correctly for me.
  • »21.01.05 - 17:42
    DJBase
    Posts: 745 from 2003/4/6
    Open a shell, type version and if you have Kickstart 50.60 than its 1.4.2 I guess.
  • »21.01.05 - 18:19
    cecilia
    Posts: 459 from 2003/8/30
    AH! well, now I know i have kickstart 50.56
     :-D
  • »21.01.05 - 21:38
  • DDJ
    DDJ
    Posts: 99 from 2003/2/23
    Just to know, in ann someone said about a 1.4.3 version from some kind of iso in a ftp site, can anyone here confirm if this is true or not ? and if yes wath is new in this version ?
    Peg2 G4 1Ghz rev. 1.2 - CPU rev 1.2 - Built on 20050808
    OF-version 1.2 (20050808153840)
    Radeon 9250 (9200Pro) 256MB/128bits AGP - OEM PCVIEW (ProLink)
    RAM 1GB - 2x512MB DDR333 CL2 - Kingston HyperX
    40GB ATA100 - Brand ?
  • »28.01.05 - 13:04
    SoundSquare
    Posts: 1214 from 2004/12/1
    1.4.3 is same as 1.4.2, just parallel.device and another file changing, files you can get here so it's pretty useless.
  • »28.01.05 - 13:15
    Hawk
    Posts: 204 from 2003/12/29
    I think I m still with 1.4.1 I just updated the USB stack separately. What's worth the upgrade?
    By the way, if you wanna MorphOS 1.5, I know one possible solution:
    surpass X86/Windows in the RC5-72 project! :-P MOove on!! XPPP
    I guess that if we manage to do that, further updates and other candies would be available :-P
    Pegasos II G3@600Mhz (no fan) 512MB RAM (1 slot)
    -- Maxtor 6Y120P0 120GB, 7200 rpm -- ATI Radeon 7500 - (64MB, TV-out)
    -- Minuet Slimline PC case -- MorphOS 1.4.5 + Gentoo
    EFIKA
  • »29.01.05 - 01:13
    Henes
    Posts: 507 from 2003/6/14
    You can visit http://support.morphos.net/ and register. Then you
    should get access to the support stuff: updates, ML services, etc...
  • »29.01.05 - 01:53
    Golem
    Posts: 766 from 2003/2/28
    The new ide.device fixing lockup issues experienced on some setups (and some other stuff I can't recall).
    [ Edited by Golem on 2005/1/29 5:15 ]
  • »29.01.05 - 02:12
    Robin
    Posts: 741 from 2003/2/24
    wasnt 1.4.2 the update that fixed the fragmentation ?
  • »29.01.05 - 04:36
