Looking for more MorphOS programming Resources.
    liquidbit
    Posts: 407 from 2003/10/12
    MOS users and programmers.
    Except the Aminet & MDC, what other resources you people know?
    I'm talking about e-books on pdf or other type format which would help as all to understand better the OS and we can start programming with C/C++ on MOS.
  • »29.10.04 - 07:19
    smithy
    Posts: 49 from 2003/12/30
    Hey LiquidBit!
    You should try to get a hold of Amiga Developer CD 2.1 (The AmigaOS 3.x one, not the DE SDK one). Apart from the ROM Kernel manuals it also has the AmigaMail articles (many of which were written by Commodore engineers) which I thought were excellent, and has other documentation from various devcons and NDKs.
  • »29.10.04 - 08:58
    Posts: 1520 from 2003/2/24
    Take a look into Amiga C ml.
    It is quiet nowadays but good resource for hints and tips.
    [ Edited by itix on 2004/10/29 17:03 ]
  • »29.10.04 - 12:02
    Posts: 154 from 2003/4/22
    'lo
    The MorphOS Development Reference manual gives precious information
    about MorphOS.
    Very interresting when you port a 68k application to PowerPC.
    It's included in teh SDK or can be find here:
    http://zapek.nerim.net/docs/morphos/morphos.pdf
    MorphOS Rulez !
  • »31.10.04 - 08:04
    tokai
    Posts: 1289 from 2003/2/25
    - first get MOS SDK (it contains already a few good examples).
    - then get the examples which we have uploaded to mdc.morphos.net file section (itix calculator examples or snes9xstarter source are good starts)
    - download mui38dev.lha from aminet (it contains additional and helpful information about MUI programming)
    - get muiundoc from aminet too (contains information about a few interesting, but undocumented MUI features)
    - don't forget to have a look to the standard documentation about gcc/c/c++ inside gg:guide/ (installed with MOS SDK)
    - download AmiTCP/IP SDK from aminet if you plan to make network related applications (only for documentation, includes are already present in MOS SDK)
    - check eBay for an Amiga Developer CD (i suggest to get a v1.2, it's probably cheaper and contains already everything you need for MorphOS. v2.1 comes only with extra stuff you don't need (e.g. includes have new copyright header and other useless things ;-) )).
    that's all what you need, really. Maybe a good c reference book too (e.g. the C pocket reference from O'Reilly), but that's really everything. The rest depends only on your skills.
    happy coding!
    regards,
    tokai
    [ Edited by tokai on 2004/10/31 12:04 ]
  • »31.10.04 - 10:04
    liquidbit
    Thanks guys..
    The most of the books you recomend I have them already.
    I have expierence with C++, and when I tried to compile my own C++(win32) programs I get a lot of errors...
    I 'm not a C guru so I need some practice.
    I would like to find more info about
    1.MUI 3.9
    2.SDL libraries
    3.TCP/IP
    liquidbit
  • »01.11.04 - 07:27
    Jupp3
    Posts: 1193 from 2003/2/24
    C++ code doesn't work with the C compiler in the SDK. You need to replace 3 files from the older one.
    On a second thought, maybe just installing a newer gcc should be enough?
  • »01.11.04 - 07:58
    liquidbit
    jupp3,
    I'm trying to compile with g++ compiler from the MOS SDK. Are the libraries then broken ?
    How can I make it work?
    Actually if it works I dont have to to do many changes on my programs (for people who are interesting to know what for programs: they are just scientific programs[command line] with use of COM1 line [ROBOT-ARMS]&[GPS Antennas].
  • »01.11.04 - 09:09
    aliem
    Posts: 85 from 2003/12/11
    Innoidea has a huge function repository:
    http://www.innoidea.hu/subsites/amiga/developer/
    :-D
    ByE
  • »02.11.04 - 09:52
    Look into here for basic SDL documentation.
  • »02.11.04 - 13:31
    Posts: 2066 from 2003/6/4
    Well, wanted to install gcc 2.95.4 today, but was traped in
    decompressing probs (I am highly uncomfortable with all those non
    lha/lzx/zip formats due to my computer history).
    I tried to decompress the tar.bz2 first with gg:bin/bunzip2 -d and the
    resulting tar archive (17 264 640 bytes md5:
    110fb895c4603f1f7a21dac376b7cb0) with gg:bin/tar -x but nothing
    happend.
    Anyone a hint what's wrong..?
  • »28.11.04 - 22:04
    Golem
    Posts: 766 from 2003/2/28
    Use "tar -xf archive.tar" to extract it.
  • »28.11.04 - 22:35
    Thanks, that did it - I guess I should have read the --help output
    more carefully...
  • »28.11.04 - 23:01
    Jonny_Rico
    Posts: 45 from 2004/3/18
    Someone should put up together all informations about contributing to MorphOS as developers are not giving out any relevant informations ... f.e. see statement Attention Software ... "Also we tried to contact several MOS developers to ask for a possible solution, like radeon 3D drivers for MorphOS, but without any luck :(." ... and they are far not the only ones who needed dev. support.
  • »26.12.04 - 17:15
