Posts: 929 from 2003/7/13
Timofonic, you should be hearing more about Papyrus as more customers download it or get their packages in the mail.
I downloaded my Papyrus on Saturday. I've only spent about an hour with it so far, so I can't say too much. It's very responsive. It has a surprising amount of features. You can put pictures in your documents, resize and move them around with the mouse easily. I like Papyrus MOS. But it has some problems too. Hopefully we'll get some updates and they will improve Papyrus.
I ran Papyrus at the same time as playing a DVD with Devedie and MPlayer and this worked fine. Papyrus runs in a window, and I put the DVD window under the Papyrus window and was using Papyrus while the DVD ran, and that was nice. :) On G3! However I have not used Papyrus enough to tell you if it is good enough or not good enough overall.
It is the most ambitious program I ever saw for MorphOS, though. It does a lot of stuff!
Pegasos2 G3, 512 megs RAM
