Stratagus Problems
    weiseb
    Posts: 215 from 2003/3/29
    Hallo
    I have problems getting Stratagus to work. I downloaded Stratagus at
    www.akcaagac.com/tools/files/lzx/stratagus-mos.lzx
    followed the instructions from
    https://morph.zone/modules/newbb_plus/viewtopic.php?viewmode=flat&order=1&topic_id=2039&forum=16&post_id=&refresh=Go
    to get the WC2 data files.
    With this I get:
    [string "LagFFS:dbs/data.wc2//scripts/stratagus.lua"]:242: attempt to call global `SetFogOfWarGraphics' (a nil value)
    stack traceback:
    [string "LagFFS:dbs/data.wc2//scripts/stratagus.lua"]:242: in main chunk
    When using the last stable release of Wargus I get:
    (null)
    src/unit/script_unittype.c:1004: Unsupported tag: Transporter
    stack traceback:
    [C]: in function `DefineUnitType'
    [string "LagFFS:dbs/data//scripts/human/units.lua"]:482: in main chunk
    [C]: in function `Load'
    [string "LagFFS:dbs/data//scripts/units.lua"]:430: in main chunk
    [string "LagFFS:dbs/data//scripts/stratagus.lua"]:361: in main chunk
    I am not sure if I did anything wrong or if it does not work because the Versions of Wargus and Stratagus are different.
    Any ideas?
  • »23.10.04 - 09:29
    Posts: 979 from 2003/6/28
    Lets see what porters say...
    There will be a new Stratagus version soon? And a MorphOS port of that?
  • »23.10.04 - 14:23
    weiseb
    Ok I will write an email tonight.
  • »25.10.04 - 11:12
