DVD Burning
    Hawk
    Posts: 204 from 2003/12/29
    After several months I am still not able to burn DVDs under Pegasos. What do u guys use?
    That version of cdrtools for MorphOS just hung up.
    In Gentoo Linux I tried emerging the cdrtools and then downloading the cdrecord-prodvd binary from Schilling page
    ftp://ftp.berlios.de/pub/cdrecord/ProDVD/README
    But since the binary for powerpc-unknown is more than a year older, it seems that the key is not working... I tried writing the author several times, but no advance... Last time, he asked me my MAC address to make me a key, but then he never replied again.
    The other day I saw that dholm had added a ~ppc version of dvdrtools. I uninstalled cdrtools and tried that one. But mkisofs is not working (always complains about unreadable files!), and dvdrecord seems to work, but just after beginning gives and input/ouput error and stops.
    What do u guys do?
    Though a bit sad, I am considering buying a PC just to be able to burn....
    Pegasos II G3@600Mhz (no fan) 512MB RAM (1 slot)
    -- Maxtor 6Y120P0 120GB, 7200 rpm -- ATI Radeon 7500 - (64MB, TV-out)
    -- Minuet Slimline PC case -- MorphOS 1.4.5 + Gentoo
    EFIKA
  • »24.08.04 - 23:04
    Spidey
    Posts: 568 from 2003/2/24
    Hi Hawk,
    I'm just waiting for BurnIt.
    At the moment I use the pc for this purpose.
    But even when we can burn DVD's, we still have the problem of the 2 GB sadly enough...
    Bye,
    Spidey
  • »25.08.04 - 06:31
    McGreg
    Posts: 17 from 2003/4/16
    Hmm. I am burning DVDs with pegasos/linux since quiet long without any problems.
    Using k3b with debian. Works just excellent.
    Gregor
  • »25.08.04 - 09:01
  • Ray
    Ray
    Posts: 21 from 2003/2/24
    You can burn DVD with growisofs under Linux.
    http://fy.chalmers.se/~appro/linux/DVD+RW/
  • »25.08.04 - 15:39
    ChatDEau
    Posts: 248 from 2003/4/4
    @Hawk
    As mentionned in few other threads, the next FryingPan, version 0.4, is almost out.
    I am betatesting it, and there is no problem at all to burn on any kind (+ & -) of DVDs, even up to 4GB.
    *** The 2GB limit is not only an issue on AOS/MOS, but on ALL 32-bit OS.
    The only issues are with MOS itself up to now, and those are:
    - File size limit = 2 GB - 1 byte (only problematic if you want to create an ISO before burning it)
    - CDFS -> Can't read behond the 4GB limit
    I burnt many 4.7GB DVDs successfully. They still can't be read behond the 4gb limit in MOS, but can be read correctly in any other OS, as their CDFS has been fixed since quite some time.
    Fred
    [ Edited by ChatDEau on 2004/10/1 23:00 ]
  • »25.08.04 - 15:57
    Posts: 2730 from 2003/2/24
    There can be/will be ways around that. But it will for sure be much less convinient than on, say, Windows ... :-/
    MorphOS needs a new file system!
  • »25.08.04 - 16:06
    Posts: 54 from 2004/6/16
    Is that 2Gb still a limit if using SFS?
    Can PFS be used under MOS? (I just got PFS2 for my A3000)
    Not that I've got any 2Gb files anyway :-D
    -~= Amiga Cats don't get Microsoft worms! =~-
  • »25.08.04 - 17:41
    Posts: 979 from 2003/6/28
    @takemehomegrandma
    SFS2? :-D
  • »25.08.04 - 17:48
    Posts: 1087 from 2003/3/24
    Has it only a problem with files over 2GB or dose it have a problem with a DVD filled over 2Gb???
    [ Edited by ThePlayer on 2004/8/25 22:25 ]
  • »25.08.04 - 18:02
    @ThePlayer
    It seems both things...
  • »25.08.04 - 18:07
    ChatDEau
    @ThePlayer & ALL
    FILESIZE limit = 2GB - 1 byte
    CDFS (CD-rom File System) limit = Problem with DVD filled more than 4GB (for reading).
    Whatever File System you use, the 2GB FILESIZE limit is an issue with dos.library that can't be easily fixed.
    Fred
  • »25.08.04 - 18:29
    Hawk
    I finally managed to burn DVDs ^^;
    But the only program that works for me is growisofs (thanks Ray). All the others just hang up. The thing is that I didn't know that you could burn any ISO file with growisofs so easily! (-_-)u The tricky point is that I have to add an option twice! Don't ask me why ...:
    growisofs -dvd-compat -dvd-compat -Z /dev/dvd=/home/mm/MY_VIDEO.ISO
    By the way, my burner is:
    MITSUMI DW-7872TE
    for dvdrecord, I guess a Pioneer would work better ... ^^;
    EFIKA
  • »01.10.04 - 13:46
    magnetic
    Posts: 2129 from 2003/3/1
    Great to hear you have it working..
    Fyi Burn it 3 does burn DVD nicely on MOS...
    Also, be sure to try K3b in linux - its an excellent program with a nice intuitive GUI.
    magnetic
  • »01.10.04 - 16:25
    Hawk
    But Burn It 3.0 is not available yet, rite?
    I went to its home page and still it's written SOON
    EFIKA
  • »02.10.04 - 00:02
    killlbilll
    Posts: 95 from 2004/5/19
    How fast have you managed to burn a dvd? I have a 16x writer, and 8x media, and cannot get more than 1.9x in k3b/gentoo, and about the same speed using fryingpan/mos. Any ideas why?
    [ pegasos ii / g4 | morphos1.4.4 ]
  • »02.10.04 - 18:59
    Trizt
    Posts: 17 from 2003/6/1
    @magnetic
    k3b is just a frontend for cdrtools/dvdrtools and cdrdao.
    @killlbilll
    With growisofs I have managed 4x with 4x media.
    I did patch cdrtools 2.01alpha38 with all the DVD related patches, but sadly this don't go well, everything compiles except the cdrecord itself, this is the case with both the gnu-make and smake (that is recommended for building cdrtools). I guess we have to kind of live with the case that drivers and software aren't developed for PPC, but only for x86 and we may be lucky that it works on PPC.
  • »05.10.04 - 14:27
    Taerwin
    Posts: 26 from 2004/8/2
    Hello,
    FYI I have successfully burnt a DVD using FryingPan 0.3
    Now the data consisted in a back-up of all my photographs (I gave a very quick check by opening a few photos at random).
    Yet I cannot tell you the total size of the whole data (it apparently exceeded DirOpus4 capacity so the total size was negative ;-) I made a rough estimation from the sizes of the directory, ruled it could fit in a DVD and pressed burn ;-)
    Regarding the speed I really don't remember except that I deemed it acceptable - I mean the whole process was done within - say 10 or 15' but I am quite sure it was faster than 1.9x
    My config: PegasosII with Plextor DVD burner
    PegasosII G4 - 512 Mb - Voodoo 3
    Amiga 1200/603e - 256 Mb - BVision
  • »14.10.04 - 09:32
  • Ray
    Ray
    You can check data consistency with CRCtoy. :)
    http://amigos.amiga.hu/ray/CRCtoy
  • »14.10.04 - 21:09
    Taerwin
    Hello,
    To complete my previous post: I burned another DVD this WE using FryingPan v0.3
    total file size neared 4 Gbytes; write speed was around 40x (from FryingPan). Job was completed within 10' (minutes).
    My DVD burner is an IDE Plextor PX-108T
  • »18.10.04 - 06:32
    ChatDEau
    Hello,
    I also burnt many DVD+Rs, but using FryingPan v0.4a (registered) without any problem whatsoever, even putting 4.37GB (max size) of data.
    The only issue is still with MOS, which can't read the data on DVD behond the 4GB limit. I tested burnt DVDs on a PC and data is correct.
    My DVD Writer (which only does DVD+R) is a Plextor PX-504A.
    Fred
  • »18.10.04 - 17:32
    Furvert
    Posts: 83 from 2004/4/20
    Where can you get Frying Pan though. The site listed doesn't have the files. 3.2 is shown but the files aren't there.
    Furvert
    [ Edited by Furvert on 2004/10/19 1:45 ]
  • »19.10.04 - 03:41
    MarK
    Posts: 641 from 2004/1/25
    Please be patient, author of the FryingPan was off for about 6 weeks and during that time he had not access to the internet. And his pages were under reconstruction, and still not finished. Please register to yahoo's fryingpan_amiga ML and there You will be able to get the latest releases.
    Now FP's author is again back, so I'm sure it will take not more, than few days to finish the pages.
    Bye, MarK.
  • »19.10.04 - 04:13
    Kaczus
    Posts: 199 from 2003/9/6
    Autor come back. He works on new version of FriyngPan. He was very
    happy, when he has got Pegasos from Itix, but unfortunately this peg
    is burnt :(. And he must works still on UAE :(
    Kaczus/BlaBla & AUG-Lodz Happy Pegasos User
  • »23.10.04 - 15:30
    MarK
    Yes, he bought lots of peripherals and now he had to sell it again :-( I think, he should get a new board for some special price... we need a man like Tomasz Wiszkowski is!!!
    Bye, MarK.
  • »25.10.04 - 05:25
