Word Document Converter
    ChatDEau
    Posts: 248 from 2003/4/4
    Hi there!
    It's been a long time I haven't needed to convert a Word document into something readeable on MorphOS / AmigaOS.
    I wonder what is the most up-to-date tool to do so. Don't tell me Papyrus, I just need a simple tool for the moment!
    Converting to RTF, HTML, PDF or TXT would be (in order) what I'd prefer.
    Any suggestions?
    Thanks ;)
    Fred
  • »14.10.04 - 01:36
    stefkos
    Posts: 97 from 2004/2/4
    check antiword...
    www.tbs-software.com/
    in morgoth part of site you will find antiword and on stefkos part you
    will find GUI for it.
  • »14.10.04 - 05:13
  • psd
    psd
    Posts: 35 from 2004/3/21
    You can try this one: http://www.schneewind.net/AntiWordGUI.lha
  • »14.10.04 - 14:50
  • jah
    jah
    Posts: 69 from 2003/3/24
    this one worked fine for me in html, it seems to support rtf,pdf and
    txt too
    http://fr3dy.meanmachine.ch/wvware.html
  • »14.10.04 - 15:40
  • bas
    bas
    Posts: 40 from 2004/4/8
    you can also use WoW
    I use it to convert word docs my friends send me
    on aminet:
    ftp://de.aminet.net/pub/aminet/util/conv/WoW.lha
  • »14.10.04 - 16:28
    Posts: 979 from 2003/6/28
    Papyrus?
  • »14.10.04 - 18:00
    ChatDEau
    @timofonic
    You didn't read my post, did you?
  • »14.10.04 - 18:43
    ChatDEau
    @psd & jah & bas
    I'll try those ;)
    Thanks guys!
    Fred
  • »14.10.04 - 18:44
