Anyone used URD (Universal Raid Device)??
    AyoS
    Posts: 410 from 2003/8/13
    ... with two slightly dissimilar drives. Do they have to be exactly
    the same as in a Hardware Based Raid Setup?
    ... has anyone used this software with scsi based drives?
    and lastly... has anyone here used URD at all??
    Thank You,
    Katos1
  • »10.09.04 - 19:58
    Neko
    Posts: 301 from 2003/2/24
    I've used it with two identical IDE drives and two identical SCSI drives (with spindle sync enabled!! although 2GB wide scsi disk isn't exactly blinding fast anyway). Works! :D
    Using it with dissimilar drives is something never mentioned in the documentation as far as I read.. maybe you should ask the author if there are some strange things that could happen.
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »10.09.04 - 23:17
    Posts: 1932 from 2003/10/19
    You can use two drives that are not the same, but both need to be IDE or SCSI not interface mixed. If you use a small driver with a larger drive the small one will be the matching size. So a 60GB and a 120GB with only act as two 60GB.
  • »11.09.04 - 00:47
    naTmeg
    Posts: 135 from 2004/2/8
    You can use ANY device in combination, even ide and scsi. About the disk-size:
    RAID0 can handle different disksizes, RAID 1 ofcos must have the same size.
    Better to say, the 'Stripe' and 'Linear' driver can handle different sizes,
    with the 'Single'-driver the disks must be the same in size.
    @Ascii >So a 60GB and a 120GB with only act as two 60GB.
    No, they act as 180GB ;)
    naTmeg
  • »11.09.04 - 09:27
  • News Moderator
    News Moderator
    Darth_X
    Posts: 571 from 2003/2/10
    I'll have to try this out sometime :-D
    @naTmeg
    Welcome to Morphzone :-D
  • »12.09.04 - 01:19
