Any XviD player available for MOS?
    liquidbit
    Posts: 408 from 2003/10/12
    Im looking a movie player which can play XviD format movies, any ideas?
  • »08.09.04 - 09:40
    Posts: 979 from 2003/6/28
    Latest mplayer ported to MorphOS seems to support it.
    It's version 1.0 pre4, and isn't a final port, seems that is in testing stage or something, that's why isn't announced...
  • »08.09.04 - 09:46
  • buh
    buh
    Posts: 68 from 2004/2/2
    I use mplayer 0.91, the first release for mos.
    It's ok. I watch many xvid's films encoded using mencoder (in linux).
  • »08.09.04 - 10:18
    Posts: 34 from 2004/4/8
    i use mplayer 0.91 its working great, it can handle the subtitles on xvid too. try this or the newest mplayer 1.0
  • »08.09.04 - 13:16
    I use mplayer 1.0pre4 that said that isn't an official port but runs great and supports matrovska...
  • »08.09.04 - 14:28
    Posts: 33 from 2003/6/17
    Sounds fine. A link to this file, please.
    PegII, 512 MB Ram, Radeon 8500, NEC USB-Card
  • »09.09.04 - 04:57
    Kaczus
    Posts: 199 from 2003/9/6
    Frogger support XVID MPEG-4 :) I think it is the best player for mos. I'd like to see full support on dvd in frogger :))
    Kaczus/BlaBla & AUG-Lodz Happy Pegasos User
  • »09.09.04 - 06:03
    Posts: 916 from 2004/1/24
    @grooves
    MPlayer 0.91:
    https://morph.zone/modules/mydownloads/visit.php?lid=90
    Mplayer 1.0PRE4:
    http://nogfx.free.fr/morphos/MPlayer10-PRE4.lha
    In the future, try the "search" option on MorphZone  :-D
  • »09.09.04 - 11:02
    Kaczus
    Don't forget about http://frogger.rules.pl :))
  • »09.09.04 - 11:08
    liquidbit
    thx thx thx .... :pint:
  • »09.09.04 - 11:29
