Saving a lot of bandwitch on remote desktop connections with
    Posts: 979 from 2003/6/28
    FreeNX is a free (GPL) implementation of the nxserver component. NX is the next-generation X compression and roundtrip suppresion scheme. It can operate remote X11 session over 56k modem dialup links or anything better.
    Could be very good make a NX client for MorphOS. It can be encapsulated the RDP (win 2k/XP/2k3) protocol and the RFB (Remote Frame Buffer, the VNC's protocol), so why not make some "Ambient Remote Protocol" and use NX? ;-)
    And I personally think that NX could be very good for things as Avalanche ;-)
    [ Edited by timofonic on 2004/9/1 12:57 ]
  • »01.09.04 - 11:49
    GK_LKA
    Posts: 481 from 2004/3/28
    I think, the main problem with the remote MOS desktop is, that MOS doesn't support multiple users well. The other OS's have correct multiuser support, so multiple users can run their programs, see their desktops at the same time at the same computer.
    [ GK / LKA Team ]
  • »01.09.04 - 13:27
    ultraspec
    Posts: 94 from 2004/1/29
    There already exists VNC which is cross-platform capable. If I understand correctly, this program is for the X11 protocol only, which MorphOS does not use.
  • »01.09.04 - 18:16
    @ultraspec
    No, It can be used with other protocols...
    And this uses a lot less bandwitch that VNC...
    [ Edited by timofonic on 2004/9/1 20:05 ]
  • »01.09.04 - 19:05
    Crumb
    Posts: 732 from 2003/2/24
    I would start with a MorphOS port of Martin Blom's rdesktop AmigaOS port...
  • »02.09.04 - 09:48
    kiero
    Posts: 129 from 2003/2/28
    I would start be using search engine:)
    https://morph.zone/modules/mydownloads/singlefile.php?lid=145
  • »02.09.04 - 10:25
    maya
    Posts: 7 from 2004/6/9
    What about the other way around? I'd really like to have the peg-screen on a windows machine....
  • »02.09.04 - 19:31
    Actually you can with VNC it seems, but it's slow, let's see if in some future...
  • »07.09.04 - 08:04
