Printing from text editors and checkbook program.
    matt3
    Posts: 784 from 2004/2/10
    I can't print from text editors or my checkitout (checkbook) and I can print from Final Writer. Any suggestions. Checkitout lets me choose PAR: OR PRT: both don't work.
    Thanks
    Matt
    [ Edited by matt3 on 2004/8/13 16:35 ]
  • »13.08.04 - 18:35
    ChatDEau
    Posts: 248 from 2003/4/4
    @Matt
    I'm not an expert with that, but if I were in the same situation, I'd try printing to a file and then sending the file directly to PRT: ... or maybe to PAR:
    That's not a solution, but this is something I'd try to see what happens.
    Hope it helps,
    Fred
  • »13.08.04 - 18:58
    matt3
    Thanks Fred,
    I created a text file of the report and tried to copy to both prt: and par: both failed.
    I'm running a network printer with lpr.device.
    Have a good one.
    Matt
  • »13.08.04 - 19:20
    Posts: 979 from 2003/6/28
    I think that we need a device sharing as Plan9 but ala amiga-style ( using .device but with tooltypes, some configuration program or something for those network things )...
  • »13.08.04 - 20:01
    Posts: 1932 from 2003/10/19
    I think what we need is a new WORKING print system. I would even pay for turbo print if they did an offical up to date working MorphOS port of it.
  • »14.08.04 - 10:28
